MF 1523 hydraulic fluid Leak
   / MF 1523 hydraulic fluid Leak #1
Cal Newsom
NE Arkansas
MF 1523
My MF 1523 Hydro (270hrs) has developed a major hydraulic leak from both Left and Right Diff. Covers where the FEL frame Attaches. Specifically, it seems the gasket between the covers and main housing is compromised (appears to be silicone). Any advice on how best to repair this leaking problem? The leak is continuous and I'm running through a lot of fluid. Thanks in advance for your help.
   / MF 1523 hydraulic fluid Leak #2
You are talking about the trumpet (axle) housings? They may be cracked, or the case itserlf. When was the loader installed?
The same happened to our 1523, stripped bolt when MMM was installed. Main diff housing had to be replaced.
Thanks for the feedback Will. I bought the tractor with the loader already installed. Axle housing appears intact & the leaking is definitely coming from the space between the Diff Housing & Diff Cover, where the gasket is apparently compromised. Looks like a big Job just getting to this as I will need to drop the loader etc.
   / MF 1523 hydraulic fluid Leak #4
There is no gasket, it is a sealer that is used. Do you have a service manual with torque specs? Please keep us posted.
   / MF 1523 hydraulic fluid Leak #5
Cal
Just wondering if you got your leak fixed. I have a 1523 the just started doing this. It is on the side that the mid mount mower raises and lowers with the 3 point arm.
   / MF 1523 hydraulic fluid Leak #6
Cal
May need to be resealed. Our trumpet housing cracked, needed a new one.
Get an MF service manual.
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
