Newholland clutch adjustment
   / Newholland clutch adjustment #1
Mikmas76
Kitale, Kenya
Newholland and Massey
Hi members,
I've got a NewHolland TT75, I replaced a clutch disc but the issue is when I engage a reverse or first forward gear, it produces a noise(like a brake jam) inside the clutch, but goes off immediately I fully releases the clutch pedal. Does it mean that I did wrong clutch adjustment of the fingers and if so can some one assist me a link with the procedure of how i can make the correct adjustment.
Thanks in advance for your assistance.
Mikmas
   / Newholland clutch adjustment #2
Did you replace the gearbox inputseals aswell...maybe there s a c-clip left outside....or the clutchdisc is the wrongway in ?
Thanks Mr DLYTrekkers, I had replaced the input seals. Ok, after inspecting the flywheel and the pressure plate I realized that they were worn out, I therefore replaced both and now the he machine is working well.
Thanks for your contribution
   / Newholland clutch adjustment #4
How do you adjust a clutch on a TN60 New Holland?
MONOSEM NG-3 LOT NUMBER 262 (A53084)
MONOSEM NG-3 LOT...
CAT D3 LGP (A50123)
CAT D3 LGP (A50123)
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53472)
2018 Link-Belt LBX...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
