Should I vent diesel storage
   / Should I vent diesel storage #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Cab Backhoe (sold), John Deere F725 Front Mount Mower, Kubota LX3310 cab.
I bought a couple of 55 gal oil drums to store diesel fuel in. They have the typical 2 inch bung and 3/4 inch vent holes with caps. I'm thinking it might be a good idea to keep them vented to prevent expansion and contraction. Ordered a couple of compressor filter silencers with 3/4 male fittings. The drums will be stored outside under a shed. They will get damp from dew and blowing rain. Should I leave them vented or just put the vent in when they are in use?
What are your opinions or knowledge on this? Will keeping it vented promote or reduce condensation in the drums?
The plan on these is to purchase 100 gallons of off road diesel to have on hand and use. I purchased a military surplus diesel generator that is equipped with an auxiliary fuel supply system. It has a bung adapter and pickup tube that fits the large hole in the drums. A secondary fuel pump and float switch senses when the tank drops below a certain level and pumps fuel from the drum to the generator tank. I figure I will use fuel from the drums in my tractor and backhoe to keep it rotated and fresh.
   / Should I vent diesel storage #2
I dont know, it will be interesting to see what others have to say about this.
On one hand, I see what storing fuel in buckets does as the temp changes. I swear sometimes it looks like a bucket is gonna pop.
But on the other hand, liquid is stored and sealed tight in barrels all the time with no issues. And there is no chance of getting moisture in there from temp and humidity changes.
   / Should I vent diesel storage #3
If the drums are vented, water will condense in the fuel for several reasons.
1) The ullage (volume of drum above fuel, where there is air) will breath due to expansion and contraction of the air inside with temperature change, this brings in fresh water vapor, which condenses when temperatures fall, and
2) as temperature of the fuel increases its vapor pressure increases, as temperature falls, the vapor recondenses, and
3) the fuel itself has dissolved air in it, as temperature increases some of the air comes out, as temperature falls some air goes back into solution, and
4) the fuel itself will expand and contract with temperature change.
The only way to prevent this is to seal the drums. The pressure in the drum will increase as temperature increases, for all of the reasons above. The best way to prevent overpressure is to not fill the drum completely before sealing it.
I would seal the drums, being sure to leave enough room for some expansion.
   / Should I vent diesel storage #4
That's as good an explanation as you can get.
   / Should I vent diesel storage #5
Never had any trouble with stored gas or diesel as long as you put 55 gallons in a 55 gallon drum (it leaves about an inch or so of head space at the top of the liquid). I don't vent, in fact, I seal mine with paint after the bung is screwed in tight. Gasoline keeps fine for about 4-5 years using PRI-G, and diesel I suspect about forever with PRI-D.
But if you seal a 55 gal barrel of gas good and tight that is about half full, and the weather turns off cold, THIS is what happens :D
ry%3D400
Which I suppose was better than the reverse, sealing it in cold weather, and when the temp increased, something blew. The fitting on the 3/4" is to connect an air hose...I blew the drum back out, then used it for scrap oil.
   / Should I vent diesel storage #6
I don't. I have 3 of those in a dedicated trailer which sits under a covering similar to a car port. They stay tightly sealed till I install my electric pump on a tank and it is partially sealed....partially because when I start pumping the ends would suck in otherwise. It stays till the tank is empty at which I move to another pump and seal off the empty. I leave an air gap at the top of about 5 gallons for expansion. Been that way for 20 years and have zero problems with fuel loss, algae and water accumulation. I use Power Services storage additive also which keeps my injectors clean as an added bonus.
   / Should I vent diesel storage #7
CurlyDave, thank you for the explanation. You answered several pertinent questions to our newly acquired hobby farm. Our local off-road diesel supplier recommended placing a filter in the system to help eliminate water.
   / Should I vent diesel storage #8
I didn't mention it but I have one at the outlet of the pump too. The Goldenrod that TSC sells make a water absorption cartridge for their after market filter cannister. That's the one I use.
   / Should I vent diesel storage #9
My two fuel tanks (100 gal, 50 gal) are not vented,,,, kinda,,,
They came with a fill cap that works like a radiator cap,,, pressurized in, or out at about 5-10 psi.
I would bet they sell these at TSC,,, it fits their tanks. They are pipe thread,, might fit a barrel?
I have had the 100 over a decade,,, no moisture gets in! :thumbsup:
   / Should I vent diesel storage #10
that is the type of cap I have on my 300 gallon overhead gravity flow tank. the cap assembly was purchased at TSC.
   / Should I vent diesel storage #11
I've got a 300 gallon gas tank on skids that I cleaned out and put a new plastic suction pipe in the end that has a metered gas pump on it. The tank is vented to the outside of the building year round via an iron pipe of around 2" diameter, with a cap to keep water from getting in.. This tank is stored indoors in my heated barn, and I had it spray foamed when I was doing my barn's walls. I use two filter's on the outlet pipe after the pump; one is a TSC fuel filter, and the other is a fuel water separator. I mark both for date and # of gallons so I know when to change them out. I buy ONLY winterized fuel due to my climate, and do not add any additives to the mix beyond the fuel being winterized already prior to delivery. I've never had a fuel issue since 2009, and probably 900 or more gallons to date.
I'd check the gallons used on the meter but I'm 5,083 miles away in the Turks and Caicos!
I decided to just leave the caps loose for now. I ordered a pair of compressor filter/mufflers that were advertised as 3/4 but they were 1/2" npt. I might get some bushings and use those but I like the radiator cap idea.
The pickup tube to supply my genset is a few inches from the bottom like any other fuel pickup should be. I will pump some off the bottom periodically to check for water.
Had a 5 gal oil can with some diesel in my garage and discovered today it split the top seal from expansion. Leaving fuel in a container that can't vent seems to be a bad idea.
   / Should I vent diesel storage #13
I'll take a wild guess and say that they used the thread-diameter as their sizing, instead of the NPT spec. I've run into that with hydraulic systems, as well, with 1/2" JIC (more properly JIC-8) being called 3/4" JIC.
I thought I would do an update on this. I decided to leave the bungs loose to allow fuel to expand and contract. Drums were filled January 2nd. I pulled about 30 gallons out of one a couple of months ago. Emptied it today and took a few gallons out of the other drum. Before I started today I took a sample off the bottom of both drums and have no water or sludge. When drums were filled I added an once of Killem Biocide in each one and half a bottle of Stanadyne lubricity formula.
   / Should I vent diesel storage #15
I wonder if that is what they do to store their diesel in Bangladesh?
   / Should I vent diesel storage #16
A common problem with diesel powered boats is condensation in the tanks that leads to algae buildup. I had that problem on my sailboat with two 50 gallon tanks that were always vented.
Out in the high desert with lower humidity, it might not be as much of a problem. I have two 300 gallon fuel tanks for my oil boiler that show no signs of any water or algae after just two years of sitting with open vents.
I also have six 55 gallon drums full of stored fuel for heating later. They are all tightly sealed. No problem with them either. They will build up some pressure but they are designed to deal with it. A nice idea is to paint them white or keep them out of the sun, but it's not necessary.
One other problem is if they are upright and collect water around the bungs, where the tank seal can be higher than the bung opening. Or have melting snow sitting on them. Be sure to have them absolutely tight and sealed or the water will get in when they cool. I used steel bungs and wrapped teflon tape over the top of the o-rings before I installed them.
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2413 (A60432)
2413 (A60432)
2349 (A60432)
2349 (A60432)
2388 (A60432)
2388 (A60432)
