VaBeekeeper
Member
- Joined
- May 16, 2012
- Messages
- 31
- Location
- King George, VA
- Tractor
- 2016 Kubota L3901 HST with LA-525 front loader
Hey Folks,
My Kubota L3901 HST is having a problem. I bought it new from the dealer this summer (only 20 hours on the odometer so far) and got the KTAC insurance, so I guess I should just contact the dealer and let him take care of the issue... but hey, if it's a minor adjustment I can do without voiding the warranty, I'd like to avoid the time and hassle of getting the repair shop involved. So I turn for advice to the great knowledge base of my virtual friends here in Internetville...
The problem is that my tractor "thinks" the PTO is engaged even when the PTO lever is in the Off position. And sometimes the tractor is right: after pressing the clutch pedal, moving the lever from On to Off, and slowly releasing the clutch pedal, the PTO resumes spinning. It's not supposed to do that! More often, the PTO shaft doesn't spin, but if I get up off of my seat, the seat kill switch kicks in and shuts off the tractor. Again, it's not supposed to do that.
I think I've sort of homed in to the location of the problem. (Please bear with me for this long-winded explanation, or skip to the next paragraph.) The PTO lever mechanism is supposed to press against a small switch when the lever is moved to the OFF position. But in my case moving the lever doesn't always cause the switch to be activated, or to stay activated. If I move the lever all the way to the very back of the slot it's in, until it bumps up against the edge of the sheet metal housing, then, yes, the switch activates. I hear a distinct "click" when that happens, and when I subsequently release the clutch pedal, the PTO does not spin. On the other hand, if I just move the lever far enough back so it can lock into the "Off" side slot position, without going all the way back to the edge of the housing, then the switch does not activate, I hear no tiny click, and the PTO shaft resumes spinning upon releasing the clutch pedal. Thus, it appears that the switch must be activated at least momentarily for the PTO not to spin. In either case, though, if I attempt to dismount the tractor, the kill switch under the seat shuts down the tractor. So that switch evidently must be pressed all the time to let the safety interlock system know that the PTO isn't running. Indeed, I am unable to start the tractor at all unless I take one hand and push the PTO lever all the way back while I use the other hand to turn the key.
So it appears that the PTO control lever isn't pushing on the PTO OFF sensing switch sufficiently, if at all, when the lever is in the rear, "PTO OFF" position. I took at look at the assembly and noticed that there is a lot of lateral play. To illustrate, I'll show you two photos for comparison.
Okay, so we have two photos of the PTO control assembly, looking from the back of the tractor just behind the seat. That big orange vertical bar is the PTO control lever; it's currently in the "OFF" position. Now take a look at the bolt and washer toward the lower center of the photos. Notice that in one photo, the bolt and washer are snug against each other, while in the other photo they aren't. That second photo, where there's some slack between the bolt and the washer, produces the condition where moving the lever to OFF uniformly results in activating the PTO OFF switch and keeping it activated (what we want). In other words, it seems that if the bolt were tightened so that there wasn't as much "slop" allowing the lever linkage mechanism to move laterally, the problem would go away. But I have taken a wrench to the nuts and bolt-heads, and I haven't detected anything that feels loose, and I don't want to force anything (remember my concern about voiding the warranty).
So what should I do? Does anyone out there recognize the problem and know an easy, low-risk adjustment? Or should I just play it safe and call the repair shop, even though it'll mean that my tractor is out of action for a couple of weeks?
By the way, thanks again if you waded through all my verbiage...
