Mitsubishi D1600FD Lift Arms wont go wide enough
   / Mitsubishi D1600FD Lift Arms wont go wide enough #1
MountainManMike
Gatesville, Tx
Ford 851, Mitsubishi D1600FD
Need to get my lift arms to go wider (for some Cat1 implements that I cannot turn the pins to the inside). Found some longer arms with offset at Hoye tractor but I'm not sure if they would work. Anyone have experience with this issue?
Thanks, Mike
   / Mitsubishi D1600FD Lift Arms wont go wide enough #2
Hello mike, I have no experience with that tractor and don't know if it's possible, if they make wheel extenders you could move your wheels wider and give you more clearance between your wheels and maybe your three point arm will swing wider and also give you better stability.
   / Mitsubishi D1600FD Lift Arms wont go wide enough #3
Thanks, Mike
Sometimes you can switch sides with the rear tires to take advantage of the dish on the rim? Ken Sweet
   / Mitsubishi D1600FD Lift Arms wont go wide enough #4
i used a quick hitch and put the pins facing inward to clear tire chains on my old kubota.
(1) MAYTAG REFRIGERATOR (A51248)
(1) MAYTAG...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2121 (A51244)
2121 (A51244)
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
