Sickle Bar John Deere 3046R sickle bar SB3107 question
   / John Deere 3046R sickle bar SB3107 question #1
cooljoe00
Member
Nichols, sc
Kioti NX6010HST Cab
I was looking at a John Deere 3046R, but I was checking the compatibility list of the sickle bar SB3107, and this tractor is not in the list. Does any one know why? or if there is a sickle bar out there that is compatible with this model tractor.
   / John Deere 3046R sickle bar SB3107 question #2
I run one on my 3320 with no issues
This is the article clip that I am referring to.
Sicklebar Mowers
Rough cuts made easy. Double-action cutting bar makes quick work of
ditches, hay fields and varying terrain. These Category 1 hitch-compatible
mowers include hydraulic-lift cylinders for the cutting bar.
69-in. cutting width 25-50 hp SB3106
3320, 3520, 3720, 3032E, 3038E,
4005, 4105, 4120, 4320, 4520, 4720,
4044M/R
81-in. cutting width 25-50 hp SB3107
4005, 4105, 4120, 4320, 4520, 472,
4044M/R
92.5-in. cutting width 25-50 hp SB3108
4044M/R
The models 3033R, 3039R, 3046R are not in the list. The only 'R' tractor in the list is the 4044R. I was wondering if there was so kind of reason their not in the list, or if they still work on the other 'R' tractor just not listed.
   / John Deere 3046R sickle bar SB3107 question #4
My guess is the list is just not updated with the current models.
   / John Deere 3046R sickle bar SB3107 question #5
I would also bet the list is not updated. What will you be doing with the sickle mower? Ken Sweet
mowing ditches.
   / John Deere 3046R sickle bar SB3107 question #8
What is "double action" (in regards to a sickle bar)?
   / John Deere 3046R sickle bar SB3107 question #9
The guard bar and section bar both move instead of just the section bar, as seen on conventional mowers. Ken Sweet
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A57024)
2017 Yale GLC050VX...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Standing Metal Firepit (A55853)
Standing Metal...
Plastic Bear Statue (A55853)
Plastic Bear...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
