Auger/cement mixer skid steer attachments
   / Auger/cement mixer skid steer attachments #1
Sun Treader
Member
Western Virginia
Case IH 495
No one has ever seen one of these in action or has an opinion?
Hydraulic auger that will also mix cement and using the loader be able to carry it from mix site to use site or even lift it up to pour wall forms or group CMU?
   / Auger/cement mixer skid steer attachments #3
I laid quite a bit of mixed concrete with a plug in cheapie mixer then dumped that into my skid steer bucket to take over to the pour. That unit is quite picey unless you have a daily or weekly use
   / Auger/cement mixer skid steer attachments #4
This is why the hydraulic units aren't very popular- the little electric mixers can be had at near throw away prices and are easily moved by hand.
If you need more "control" than a standard bucket they make concrete SSQA buckets.
I'm working with a little electric mixer and its a great unit, no question there. I've rented mortar mixers when I had enough mortar to keep it busy. We're grouting a CMU wall now and with the electric that involves mixing, wheel barring, and then lifting buckets up to place. My thinking with a loader mounted mixer is it could lift and place directly without all the heavy labor. This is all just person stuff playing around the farm, no where near commercial, daily, or even weekly use.
The Danuser type horizontal auger mixer and placement buckets would be ideal but they're $5k. I'd also like a hydraulic auger for regular hole digging. This unit isn't much more expensive than a skid steer type hydraulic auger alone and you get a versatile way to mix, carry, and place as well. Might work for my uses, but lots of better solutions for more frequent users.
Modine Shop Heater (A51573)
Modine Shop Heater...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
