Backhoe Kubota bx 23 La210-1 bt600
   / Kubota bx 23 La210-1 bt600 #1
Gino1950
Williamstown
Kubota bx23 bt600 La210-1 loader
Just bought a Kubota BX 23 with loader LA210-1 and BT600 with 353 hours it was never serviced already blew a backhoe line differential lock does not work of course the air filter bracket is broken but love the tractor
   / Kubota bx 23 La210-1 bt600 #2
There may be an online version, but if not, a worthwhile investment (available other places as well)
WSM - BX23,LA21-1,BT6 Jul '6
May be worth putting a gauge on the hydraulics to check relief valve setting.
   / Kubota bx 23 La210-1 bt600 #3
If the differential lock is not working, you need to check why, if the pin or other parts are sheared or broken there is a chance of the parts getting wedged in the rotating parts and busting the transmission case, which is an expensive repair.
David
   / Kubota bx 23 La210-1 bt600 #4
Low hours, some neglect, hopefully you can turn it around. I have the newer (2013) Bx25D with same hours and love it. Find the (WSM) workshop manual and do a complete service. Another great forum is
OrangeTractorTalks - Everything Kubota - Powered by vBulletin
Between the 2 you should find the WSM for free.
Ask questions and somebody will answer, you have a good machine!!
   / Kubota bx 23 La210-1 bt600 #5
The differential lock can be a little tricky to engange, mine will sometimes take several seconds to engange, steering back and forth a little will sometimes help as you drive slowly forward.
Will do. Thanks
Will try Thanks
   / Kubota bx 23 La210-1 bt600 #8
The BX23 is a little tank. A great little TLB. I bought mine with the intent of selling it when I was finished with backhoe projects. But the backhoe is so handy, I don't think I'll ever sell it.
Yes they last a long time if maintained I am going to keep mine also. How many hours on yours
   / Kubota bx 23 La210-1 bt600 #10
I believe all the air filter brackets break on these tractor. I had some scrap metal and shaped it to brace it a little better. Might say I added some beef to it and it's held up since. As far a diff lock you have to hold it down while using it the minute you let up it disengages. Very good little tractors that can do lots. I got mine about six years ago used and it had little over 3'hundred hours and haven't been disappointed with it yet. Installed several hundred feet of water line, sewer lines, driveways, clearing, tilling, mowing, bushing hogging, moving dirt. And the list goes on and on. May not be the fastest in the world but handy as can be.
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
