Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #4,461
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=500780"/>The little tractor that could. I removed these stumps with the loader.
Wow. It's amazing what these little tractors can do. Bet that tooth bar was a huge help too.
   / Tractors and wood! Show your pics #4,462
Couldn't do it without the tooth bar. You can do almost anything, just need the right attachment.
   / Tractors and wood! Show your pics #4,464
I used the BX to haul and drag some logs yesterday.
Then we bucked the logs up.
This picture was taken a few weeks ago.
HEY. No getting off the tractor! It is simply not allowed by some unwritten rule someplace. Ya given us "seat stickers" a bad name.
   / Tractors and wood! Show your pics #4,465
Today I spent some time hauling hemlock logs across my property to were there going to get milled and used at got one load moved. I got the second load on and chained down and then the dump truck decided it didn't want to cooperate and stared running like crap , I'm not sure if it's water in the fuel or ignition troubles.
   / Tractors and wood! Show your pics #4,466
   / Tractors and wood! Show your pics #4,467
I pulled most of the 8" or less trees on a 1/2 acre lot with it although I didn't take many pictures. IMG_9390.JPGIMG_9392.JPGIMG_9393.JPG
   / Tractors and wood! Show your pics #4,468
Finished the last two of three firewood carriers today, between hail and rain showers. (Don't mention that PxLLxT word in their presence)
Made from scrap 2x4 and 2x6 boards, and old fence wire, except two new treated 2x4's for the ground contact. 48 wide, 32 deep, and 25 inside height. Holds about the same as four loads of wood in the bucket.
I found that when level full of freshly split unseasoned fir, that is all the BX wants to lift with clamp-on bucket forks. It will normally be moved when full with carryall "forks." I used two center underfloor pieces for a loose fit on the carryall forks so it won't slide sideways off balance.
These aren't furniture grade like some here make, just cheap, ugly, and functional.
Bruce
   / Tractors and wood! Show your pics #4,469
I pulled most of the 8" or less trees on a 1/2 acre lot with it although I didn't take many pictures. View attachment 500868View attachment 500869View attachment 500870
That looks fun to operate.
Bruce
View attachment 500966 View attachment 500967 View attachment 500968
They look good to me Bruce.
   / Tractors and wood! Show your pics #4,470
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2014 Jeep Cherokee Latitude SUV (A55758)
2014 Jeep Cherokee...
