Baumalight MP560 vs FAE DML/Twin
   / Baumalight MP560 vs FAE DML/Twin #1
KenB2920
Almont, Mi
Kubota L5240HSTC
Does anyone have any experience with either of these machines? Any and all info is appreciated as I am about to pull the trigger on one.
I have a baby Kubota L5240 (54 gross hp/ 52 net up and 45 PTO HP). These seem to be the only ones that I found that fit my machine. Seppi smallest is for a 60hp tractor.
I have three rear remotes so I will be able to move the rear door, top link etc.
The baumalight is a lot heavier weighing 2150lbs and the FAE is about 1500lbs. My rear lift capacity is 2900 lbs ish so I think I can handle them.
Thoughts please!!!!
   / Baumalight MP560 vs FAE DML/Twin #2
Did they offer you a demo ? What is the cost difference ? The FAE is a proven name but my son bought a baumalite stump grinder for his 35 hp JD tractor and it is well made and works awesome . The Fae may have better trade in value . It also has a cam clutch instead of shear pins . Very good .
No demo and nothing even remotely close that I can find in my area to check one out. (or either one for that matter). Is the baumalight shear pin? I have to call the dealer on the baumalight but I think it's about 5+ grand more.
I am trying hard to search and look but being I have such a small tractor and this appears to be a Niche market it's hard to find.
   / Baumalight MP560 vs FAE DML/Twin #4
I don’t know if it is a shear pin . What is the cost of the teeth ? The stump grinder teeth were inexpensive .
The teeth are $58 each which is pricey. The Rep told me that is retail and anytime you call will get 15-20% off. I asked what if I order an extra set now and he said he could do 30% off. Knowing teeth will be needed at some point I will just order a set. So $40 each (This is for the FAE, I don't know the cost of teeth for baumalight.). However, I think the baumalight has twice as many teeth to replace.
Just combing over some of my old threads. In case anyone cares, I went with the FAE and it's a sweet addition
This is already after being used for days.
   / Baumalight MP560 vs FAE DML/Twin #7
Kenb2920, when you are cutting brush do you run tractor in forward motion ? Does the mulcher cut well in that manner ? Do you have to go over it a second time for finer mulch ? How thick is the brush you cut 1" to 3" ? I hope to upgrade to a 60 to 68 pto HP tractor with a seppi miniforst 175. I hope to use the bucket on the loader to push down the brush and let the mulcher do its job. How do you use your equipment ?
I back into majority of the brush ... if the material needs a finer finish, I will then drive forward over it. With that said, i bring in the top link when driveway moving backward and I extend the top link when driving forward....
2003 Lincoln LS (A50324)
2003 Lincoln LS...
TMA (A49461)
TMA (A49461)
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
