10" well cap
   / 10" well cap #1
bjr
Eastern WA
Jinma JM354
Some Government Bureaucrat inspected our community Potable water well and the aluminum well cap is cracked and he made all the appropriate threats if we didn't get it replaced. I'm trying to find a replacement cast iron or fabricated steel 10" cap. All I can find is a cast aluminum for $750. We're a small (70 lots) and just don't have that kind of money. I've Googled till I'm all Googled out. This "Internet of Things" is more like "Internet of No-things". Any body got suggestions of a supplier that would actually show his product and prices on line. I would fabricate our own cap but wouldn't know if that would be consider "approved" by who knows. bjr
   / 10" well cap #2
Could you just have a welder weld the crack closed?
   / 10" well cap #3
Undoubtably your cracked well cap is cast aluminum and should be able to be welded. I would call around and find a welding shop that can handle this job. Take the cap off the well - put a plastic garbage bag over the open casing and band it down with a nylon zip tie while the original is being welded.
I think all you will find that are universally available will be cast AL. Sometimes "appropriate threats" are all that government officials have when they are lacking of sound advice.
   / 10" well cap #5
10" is large enough for a small child or animal to fall into. I'd cover it with more than a plastic bag.
   / 10" well cap #6
I would ask your "official" for specifications or a list of approved manufacturers.
Depending on what type of pipe the well casing is made of there will be cheaper options. If it is ductile iron or steel you could use a megalug with an M.J. cap. If it's cast iron then a hub fitting might work.
You could make a cap out of concrete and set an eye bolt in it to facilitate removal.
I would not spend a bunch of time until you know this guys expectations...otherwise you might just Pi&& him off.
   / 10" well cap #7
Check with local fabrication shop to make one out of stainless steel.
   / 10" well cap #9
   / 10" well cap #10
Can you show a picture of your well cap. $750.00 for a well cap no way I would pay that.
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2019 FREIGHTLINER CASCADIA SLEEPER (A54607)
2019 FREIGHTLINER...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
CAT 420D IT (A47477)
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
