Air compressors, cold weather, oil choices.
   / Air compressors, cold weather, oil choices.
Well, if I ever buy an $1800 compressor, I'll probably put good oil in it. For a Harbor Freight compressor, I think Harbor Freight oil might be okay. Or maybe even a $6.99 bottle of Rarus 427.
Or was that just another subtle plug for Amzoil?
   / Air compressors, cold weather, oil choices. #42
Maybe, that's what I use in it though. Just like your plug for an HF compressor. lol
This is the only large compressor I have ever bought. I figured I would get one that would do everything I ever wanted to do.
   / Air compressors, cold weather, oil choices. #44
   / Air compressors, cold weather, oil choices. #45
I don't worry much about oil, but I always start the compressor, a old sears model, with the drain valve open, so there is no load on the machine, let it run for 30 seconds or so, then close it. I've started it below zero here in Michigan.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
378811 (A51573)
378811 (A51573)
