thickest 2x2 square tube to fit receiver hitch
   / thickest 2x2 square tube to fit receiver hitch
Why do you want hollow tubing instead of solid on a subsoiler? Just asking.
Steel is usually sold by the pound.I thought the 2x2 1/4" tubing would be easier to find local.I would have to drill the hole for pin through the solid piece.
   / thickest 2x2 square tube to fit receiver hitch #12
Is this one of those projects where you might be able to buy something already made VS making it yourself?
I've used onlinemetals.com for smaller pieces....
YIKES! 2" square solid steel is salty!!!
Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com
How about something already made for not much less than a 3' piece of new square stock?
Tarter Subsoiler SUB by Tarter Gate Co Llc for $161.97 in Tarter - Brands : Rural King
   / thickest 2x2 square tube to fit receiver hitch #13
I've built several. Usually use 1/4" wall.
Where a problem appears is if you try to use normal square tubing to make the female part.
\I learned that the receiver (female) part is METRIC tubing.
Local steel supplier carries it.
Also it has no weld seem on inside.
   / thickest 2x2 square tube to fit receiver hitch #14
Sq tubing and pipe is sold by the foot.
   / thickest 2x2 square tube to fit receiver hitch #15
Unless you buy it from midwestmetalwarehouse.com
I use them for some small items I need.
They have good prices on some small item things.
   / thickest 2x2 square tube to fit receiver hitch #16
Isn't tubing sized by the OD (outer dimension)? 2x2x1/4 or 2x2x3/8 or 2x2x1/8 are all 2x2 on the outside....Or am i missing something here?
Correct tube is OD dimensions. Pipe is the ID dimensions.
   / thickest 2x2 square tube to fit receiver hitch #17
Yep. It's that inside seam that is hard to deal with. :)
   / thickest 2x2 square tube to fit receiver hitch #18
If you only needed part of the square tube to be reinforced (or solid), you could buy an appropriate length of 1.5" OD stock as a welded-in insert...though a significant seam inside the 2" stock might make is a bit challenging to do the insertion.
   / thickest 2x2 square tube to fit receiver hitch #19
That is just backward, pipe OD doesn't change with thickness- schedule 40 pipe is same OD as schedule 160- the inside hole just gets smaller and smaller. Piping OD is not true sizing as example 2" pipe is 2 3/8" OD regardless of thickness.
Tubing is ID measurement, the OD changes as the tubing gets thicker. This is same for round tubing as square tubing.
Edit: not that most folks will be dealing with larger sizes but I thought I should clarify. After pipe reaches 14"nominal size the OD is the actual size of the pipe so 14"pipe OD is 14" and this is true for all sizes above 14". The thicker the pipe is then the smaller the ID becomes.
   / thickest 2x2 square tube to fit receiver hitch #20
Pipe "NAME" is ID dimensions, as the pipe was measured in early thick-wall lead pipe days.
Bruce
2011 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A58018)
2011 INTERNATIONAL...
huqvarna trak star 1270 rail demo saw (A56435)
huqvarna trak star...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
