15$ braket to save 500$
   / 15$ braket to save 500$ #1
Phil48
Eastern TownShip
CK20 HST
After 5 year of excellent service my Martin snowblower just had a major breakdown! The retaining clip inside the bearing failed and the driving shaft was push out. The driving chain was out of line and pretty much destroyed everthing on his path...
1 pic the push out shaft:
the chain got multiple fracture - scrap !
The thoot fairy paid a max on that one:
a small bracket 15$ could have prevent that mess... In the event the bearing clip fail, it wont misaligned the hole chain of command!
After being out of service for a week it's amazing how quick a bill will runup that fast! 500$
On more expensive snowblower I saw that little clip being installed - standard-
This forum is so great, and hepl me so much, I just thougt I let you know - If you have time it's a great upgrade!
Phil
PS I just tested the new and improved Martin in our last 2' of snow, just great!
   / 15$ braket to save 500$ #2
Wow, Phil. Sorry about your bad luck. Whoever built my old no-name blower solved that problem by putting a collar (with set screws) on the shaft just inside the bearing and then welded a nut onto the shaft next to the collar to make sure it would never move. I repeated that when I rebuilt (and narrowed) the blower, but your bracket would be much simpler. Thanks for the heads-up.
   / 15$ braket to save 500$ #3
Wow. Great tip! Did you have to replace both gears? Did you get them directly from MK Martin?
Clever solution !
Yes, both where pretty much destroy, my dealer order those part, not shure if there're original Martin replacement part?
100amp Battery Charger (A57454)
100amp Battery...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2011 FORD F-350 SUPER DUTY (A58214)
2011 FORD F-350...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000634, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
