My loader is not strong enough to lift my rear tires.
I think it needs adjusting..........
Green (not dried) Hickory weights around 63 lbs. per cubic foot.
How to Calculate Cubic Feet of a Cylinder
When I first bought my aluminum Debris Forks, I experimented a bit with heavy loads.
However, I do not make heavy loads a normal procedure. Repairs are too expensive.
Took down a Cottonwood nine years ago. Weighed this 13' piece of the trunk on the platform scales st 805 pounds.
Had to add more counter weight to keep the steering axle on the ground
Yep, it will easily raise the rear axle with a 26' long cedar tree. :thumbsup:
Had to go back to the shop and add more weight.
It is not as hard as it looks, here is a side view. If the loader arms are up I duck under and slide into the seat.Do you seriously climb up through the loader and over the engine of your machine to get out and take pics like this? Yikes. careful, man
