Handgun for arthritis
   / Handgun for arthritis #61
Not sure why you think 22 is better then 25.
Ahh.. never mind... I can see from that single statement that you have no business being in a gun discussion!
Terminal balistics for a 25 ACP, are across the board, lower than 22lr
25 ACP
35 gr (2 g) Safety 1,100 ft/s (340 m/s) 94 ftキlbf (127 J)
35 gr (2 g) JHP 900 ft/s (270 m/s) 63 ftキlbf (85 J)
45 gr (3 g) JHP 815 ft/s (248 m/s) 66 ftキlbf (89 J)
50 gr (3 g) FMJ 760 ft/s (230 m/s) 65 ftキlbf (88 J)
22LR
40 gr. (2.6 g) Solid[2] 1,200 ft/s (370 m/s) 104 ftキlbf (141 J)
38 gr. (2.5 g) Copper-plated HP[2] 1,260 ft/s (380 m/s) 134 ftキlbf (182 J)
32 gr. (2.1 g) Copper-plated HP[2] 1,430 ft/s (440 m/s) 141 ftキlbf (191 J)
31 gr. (2.0 g) Copper-plated RN[3] 1,750 ft/s (530 m/s) 204 ftキlbf (277 J)
30 gr. (1.9 g) Copper-plated HP[3] 1,640 ft/s (500 m/s) 191 ftキlbf (259 J)
The lowest ft# for 25 acp is a dismal 63. the lowest for 22lr is 134. In case you are bad on math, that means that on the low end, a 22lr is more than twice as energetic as a 25 acp. On the upper end numbers, 94 for 25acp, and 204 for 22lr. again.. more than twice as much energy from a 22lr.
The numbers don't lie!
   / Handgun for arthritis #62
25 ACP
22LR
souNdguy--- I think you may have to rethink those numbers on the 22lr. They are based on 18" barrel length. If you were to plug into a ballistic calculator using a comparable 2" barrel, it may look a little different.
   / Handgun for arthritis #63
Hey Gents... let's try to stick to the subject for the OP's sake. Can always start another thread! :duh:
   / Handgun for arthritis #64
Here is the deal... If the OP wants to try something else, HE has to try it first. NONE of us know his physical attributes due do his condition and the only way the OP will know what gun is the best for him due to his condition is for him to TRY it first.
I do think as mentioned, the issue at hand (no pund intended) should be addressed first, the gun issue second.
That said, I carried a 1911 for 10 years. Would not be my first suggestion due to the situation. Have no qualms with suggesting a .22LR for 2 legged critters, but I don't think it's the caliber that is the most important factor, as compared to actually actioning the firearm and shooting it per the trigger length, pull and weight.
Personally, if I was worried about big critters as the OP mentioned, I'd be leaning towards a pump rifle of some sort or hope his smith can make the ruger work.
   / Handgun for arthritis #65
Dont have to rethink anything, 22lr is beating 25acp by a factor of 2+
Sure a shorter barrel will deplete most of the bonus, but not all.
What do you hear about 25acp shootings? Outpatient removal of bullet from under skin.
22lr is a quite proven lethal round. You dont see them killing gators, hogs and cattle with 25acp...22lr? Yes.
There is a reason for that.
The BC I used has 22lr coming out about 9-10% higher fps and ft# higher.
Doubt I would use a 2"22lr, more like 6". I'll go check those #'s
Much as I thought, at 6" you are back to almost that x2 factor of ft#.
Ps, extrapolating out 25acp to 18", the best 2 performance projectiles can make about 103-120 ft#, vs 192-204 of the 22lr
So there you go.. 18" bbl, 25acp, its best 2 vs 22lr and its best 2..
What did we find.. Almost 2x factor.
Thanks for proving my point. ;)
   / Handgun for arthritis #68
Looking at 25acp on the longer bbls, its obvious it hardly benefits any if at all, its powder burns out and if its still in the bbl when powder is depleted, then pressure is dropping, and any travel of the bullet In the bore is just drag at that point.
   / Handgun for arthritis #69
25 ACP
22LR
I am not familsrbwith25acp. But I hand load and spend a lot of time reading manuals.
I am by no means any expert. But to a say I can not partake in the discussion. When I have loaded thousands, studied trajectory, is arrogance on your part. Again I am a novice. But I think can talk on some forum, with a guy who likes 22lr, because he doesn't want to admit his wife is under gunned because she is scared, or you are, is bs.
I hope your wife has time to keep pulling the trigger. I hope she is calm. I hope the guy isn't full of drugs. I hope he doesn't have a heavy coat on.
   / Handgun for arthritis #70
Also I am not advocating any rim fire for self defense. Other then better then nothing. Unless zombies or political up risings. Even I debate stopping power over quanity.
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A54865)
2018 Chevrolet...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
2018 Bobcat E26 Mini Excavator (A53421)
2018 Bobcat E26...
