New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor
   / New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor #11
Yes, I believe the part number is 965894003. Universal Outdoor Accessories Attachments Mulch kit The part number does not cross reference on parts websites and Husqvarna is not descriptive enough. I would call first to verify if you are in the market.
Yes that was the correct number for the 48" fabricated deck. I will have to order it as they only had the 48" non fabricated deck kit in stock. I also got the full line 2017 accessory catalog as they just received them today! I now own the GT48DXLS mower. I have 5 acres to mow with only 1 acre of groomed grass. That is all I will be mowing with this. I have a 60" mower on my compact tractor to handle the rougher stuff. And now the wife will mow too as she didn't like driving the bigger tractor. My wife bought me a cart for it last week for my upcoming birthday. It is a cub cadet one because I thought that's the mower I was going to get. Oh well it might not match but it'll work just fine. Here are a few pics. Thanks for the info gentleman. IMG_7685.JPGIMG_7684.JPGIMG_7681.JPGIMG_7683.JPG
You should double check the mulch kit part number. My local dealer called the regional rep and obtained a price of $90 for the mulch kit. Unfortunately, he did not provide the part number for verification. A dealer on the east coast is selling # 965894003 for $179.95 which is the lowest price that I can find online. The price difference tells me something may be wrong either the original part number or my dealer information. Also, the original part number requires a semi-permanent modification to the lower end of the mower deck.
   / New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor #13
Here is a pic from the catalog I got today. It shows that part number. I haven't ordered it yet or priced it out. I was afraid it would be the kit that required installing the baffles under the deck. I wonder if removing the baffles from the deck was part of how they improved them and came up with the "clean cut" deck?
After a closer inspection, I am still not 100% convinced of the part number. The first line says: For: 42" Fabricated LS tractor decks (2 blade) - DXLS. The second to last line says: For: 48" Fabricated LS tractor decks (it excludes the addition of - DXLS shown next to the 42" 2-blade deck). I will call Husqvarna tomorrow.
After a closer inspection, I am still not 100% convinced of the part number. The first line says: For: 42" Fabricated LS tractor decks (2 blade) - DXLS. The second to last line says: For: 48" Fabricated LS tractor decks (it excludes the addition of - DXLS show under the 42" 2-blade deck). I will call Husqvarna tomorrow.
   / New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor #16
Please post whatever you find out.
Confirmed with Husqvanra Customer Support 1-800-487-5951
Muclh Kit # 965894003
   / New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor #18
I ordered mine today from my local dealer. Will be here next week sometime.
   / New Owner - Limited Distribution Husq. GT48DXLS Garden Tractor #19
Does anyone have an idea for a aftermarket seat cover? Husqvarna's will not work with arm rests. I also need to find one for my compact tractor but that seat is a bit bigger.
My new mower finally arrived. I have not mowed the grass due to rain, but here are some initial observations and pictures.
1. The mower deck is extremely loud when running at full throttle compared to my old John Deere L118.
2. A few design or build issues:
a. The seat does not adjust back far enough.
b. The mower deck adjustment lever should have been installed on the right side. The 48" deck and extra long chute make it difficult to get on from the right side. The lever and seat arm rest make it challenging to get on from the left side unless the mower height is 3" or greater. The handle catches my leg in any lower setting.
c. The steering wheel is rotated about 45 degrees with the wheels straight.
d. Front and rear wheels inflated to 35 psi. Front max is 14 psi. Rear max is 10 psi.
3. The mower deck was not adjusted properly at the factory. The cut height was 3 3/4" on the 3" setting. The adjustment nuts are fully backed off at the end of the threaded rod to reach the correct cut height.
4. Shipping issue: The right side foot rest was damaged in shipping due to poor packaging. The chute was held up with a rubber band inside the crate with the top edge resting on the foot pedal edge (see picture). The bouncing in shipment gouged and removed several inches of paint. A simple foam insert would have prevented this issue.
ON EDIT: I had a chance to mow the lawn today. It cuts better than my John Deere so it looks like the new "Clear-Cut" deck has solved the major complaint about poor cut quality of the old fabricated decks. I mowed wet grass and it worked great without any clumping. In the Pacific Northwest, we do not have the luxury of waiting until the grass is dry to mow. The 48" deck will take some time to get accustomed to after using a 42" deck for years. I do have to turn the steering wheel considerably more than my John Deere for the same turns.
2023 JOHN DEERE 3033R LOT NUMBER 90 (A53084)
2023 JOHN DEERE...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
