gdicks
Member
On the chain drive gear on my blower there is a shaft that connects to the pto. The problem is this isnt a fixed connection, the shaft is inside a collar that connects to the PTO. These two items are "pinned" together by a small fastener less than 3/16th's which keeps shearing off.
The parts diagram for the blower does not show a shear pin for this, in fact it doesnt show that there is s pin there at all. at 3/16ths it is much weaker than the shear bolts in the augers so when pressure comes on the blower, this pin is the first to fail. Given its location inside the chain drive it requires the blower to come off the unit and the chain drive to be removed in order to replace the pin.
at less than 3/16ths I'm having a hard time finding something that will fit in there that has enough shear strength to stand up to the torque of the blower...
Any advice? I thought about a split spring pin but have no idea the shear strength of a spring vs a regular bolt. The dealer is also stumped as to the lack of a part number for this pin....
