Is it possible to find used front loader for Mahindra 4100,
   / Is it possible to find used front loader for Mahindra 4100, #1
coffeeman
Hi all.
Never had a front loader. My machine abt 10 years old. I am thinking of looking for an old used loader. Seems nearly impossible to me. But, maybe there is a lot of them out there.
Could I get measurements if I found used. I have the owners manual. I am guessing the specs might be in there. Are they basically same for all ? Is it hard to flush out the hydraulic in used one . What should an old one cost? i wonder if one might find an old one laying around cheap. I don't know. But, usually these things sort of always go with the tractor.
Cheers.....Coffeeman
   / Is it possible to find used front loader for Mahindra 4100, #2
Chances are not great that you will find a used one but you never know, just have to contact some dealers and salvage tractor yards. You may contact some of the aftermarket loader companies and get a loader that fits your tractor.
   / Is it possible to find used front loader for Mahindra 4100, #3
Have you looked?...I just did a quick search on my local CL and there were several loaders of different sizes...from $950 to $3500...with some fab work and possibly modifying the sub frame I think you should be able to find something that can be made to work...but you'll have to look...
Good Luck...
Hi there...
what is local "CL"
Don't know how to figure what size I need. My closest Mahindra dealer, 25 miles. I get close by about once a week.
I'll have to get over there and try to get educated some.
Cheers.....coffeeman
   / Is it possible to find used front loader for Mahindra 4100, #5
   / Is it possible to find used front loader for Mahindra 4100, #6
I don't see a 4100 model, but I did see a 4110. If so, Westendorf TA170 fits your unit.
   / Is it possible to find used front loader for Mahindra 4100, #7
   / Is it possible to find used front loader for Mahindra 4100, #8
...though 10 years old. buying brand new loader seems like a hefty cost. you might be better off finding a used tractor that already has a loader on it.
Totally agree. When I looked into adding a loader to a tractor we already owned, it quickly became apparent I should just buy one with a loader on it. Also, if that 4100 is not 4WD, I would not bother to put a loader on it. In my opinion, 4WD and FEL go together like Fred Astaire and Ginger Rogers. Otherwise it's like Brian Kilmeade and Rosie O'Donnell.
Rubbermaid 100 gal Poly Tank (A50515)
Rubbermaid 100 gal...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
2012 Case 850L XLT Dozer (RIDE AND DRIVE) (A50774)
2012 Case 850L XLT...
Woods 3 pt Box Blade (A50515)
Woods 3 pt Box...
