Let's build the biggest non commercial splitter ever!
   / Let's build the biggest non commercial splitter ever!
It started as a vertical column in an underground parking garage. There was going to be a 10 story building on top of it.
   / Let's build the biggest non commercial splitter ever! #13
Not that I want to criticize anyone for wanting to do a cool project, but have to wonder why? Overkill is a massive understatement.
And how are you going to move it, and with what?. 17' of that beam is in the 3600# range. That cylinder likely to add another 1000#. Axle....Another 1000#+. 100 gallon resivor, pump, massive valve, misc....Another 500#. Motor...500#. 100 gallons of oil...800#. gonna easily be a 8000-9000# splitter if not more.
As to functionality, its not gonna cycle very fast. A cylinder that size, just to cycle out and back 24" is gonna be a 14-second cycle. Which is on the slower end of what's made today.
With 165 HP and not really needing alot of psi to do the work, I'd go a good but bigger on the pump.
But all that flow comes at a price. Large hoses, fittings, and valves. You are likely gonna spend more in just the hoses than most people spend in a whole splitter.
   / Let's build the biggest non commercial splitter ever! #14
That is going to be a WILD project. How in the world do you plan on hefting "logs" up onto the I-beam and holding them in place during the splitting cycle. One tiny slip - the log rolls off the I-beam and I hope nobody's around to get crushed.
   / Let's build the biggest non commercial splitter ever! #15
I see a skid loader with forks...
   / Let's build the biggest non commercial splitter ever! #16
Anything that requires that much force in order to split is going to come apart like a bomb.
fun times though... fun times...
   / Let's build the biggest non commercial splitter ever! #18
Fair enough... but despite the throw of the cylinder... do you think it required 76T of pressure to do it? I would think a much smaller cylinder would do the job, if it had the extension.
I'm not knocking it... but for something to 'require' that much pressure, I still think it would explode. I love people's ability to make things though. It is my favorite human ability.
   / Let's build the biggest non commercial splitter ever! #19
Let's hope NH Mike adds a pressure gauge to answer that question! If you are splitting 3 foot diameter logs with 4 or 6 way split, I could imagine 40 ton might not do it...
   / Let's build the biggest non commercial splitter ever! #20
Not necessarily.
Bell's Super Log Splitter - YouTube
I can't say I would spend the time and money building it, but will certainly follow along.
Nice video. But is there a market for what's coming off that splitter?
Still needs cut, and still needs split smaller to be used for firewood. Cutting split/splintered wood with a chainsaw is a pita. So what was really accomplished, and was any time saved?
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
1R PLANTER (A52708)
1R PLANTER (A52708)
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
