I need a wiring harness for a B64 Blizzard Snow Blower
   / I need a wiring harness for a B64 Blizzard Snow Blower #1
garry
Ohio
JD 1050
I have a Blizzard B64 3point snow blower that has an electric motor to rotate the chute. I need the wiring harness that goes from the Snow Blower to the tractor. Any idea where I might find one?
   / I need a wiring harness for a B64 Blizzard Snow Blower #2
That's easy.
DPDT center off spring loaded switch and 2 wires.
A 15 v amp fuse on hot side.
Thanks, I just needed a place to start.
I understand what you are saying and I have researched how DPDT switches work. I have learned the motor is a Ford power window motor. I have acquired a 5 pin power window switch. Now my question is, can I power the motor directly thru the switch or do I need to use relays?
   / I need a wiring harness for a B64 Blizzard Snow Blower #6
Gmail
If this works* the switch shown is a DPDT spring loaded center off and is less then $10. and will handle your amperage.
Diagram shows how to wire.
My blower is controlled this way and has run just fine for over 5 years.
Fuse at 10 amps and I'd suggest 16 g wire.
(15 amps protects the wire gauge, but 10 amp covers most switches plus suspect your motor draws much less)
*(Think it did!)
(Updated from earlier post. )
Thanks for the reply. I got an error on your link. I have a Gmail account and I am signed in. 403 error says Your client does not have permission to get URL
   / I need a wiring harness for a B64 Blizzard Snow Blower #8
Sorry 'bout that.
I'll try to describe how to wire.
The DPDT switch will have 6 tabs.
You wire the outer 4 in an X fashion with a pair of outer lugs/tabs going to your motor.
The power from the battery gets wired to the 2 center tabs.
Flipping toggle in one direction will rotate one way and in the opposite direction the other way.
Just be careful that when you cross over that the X is insulated or provide good clearance.
As mentioned earlier that is a center off 2 way spring loaded switch with 6 tabs or lugs.
Can be found in toggle or rocker styles. (I prefer toggle USA quality, but that is a personal preference.)
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Wolverine Mini Skid Steer Grapple Bucket (A50514)
Wolverine Mini...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2012 John Deere 7230R (A52748)
2012 John Deere...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
