Sysop
Elite Member
- Joined
- Jun 7, 2013
- Messages
- 3,301
- Location
- Fairmont, WV
- Tractor
- Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
Your entire post was very good, and I commend you for it!
I'd like to focus on the trigger pull points...
A light trigger (single action) can be a detriment in a stressful situation....too easy to have an accidental discharge. That long stiff pull of a Glock, Kahr and some Rugers is an advantage. It's unlikely one will be taking careful aim...most likely you'll be point shooting. Point shooting takes practice. Otherwise, if you're like me, you'll be shooting low.
On the other hand, that long stiff pull on a tiny short barreled CCW type pistol does hinder "fast accuracy". When you practice enough, you will reach that same conclusion. Millions of dollars and hours in testing have proven this to the manufacturers. This is why many pistols are only double action for the first shot and follow up shots are fired as single action. I personally want my first shot to count. I also want the feel of the trigger to remain the same throughout all shots I fire. I want my brain to be processing targets, not gun handling. Gun handling should be second nature, like remembering to breathe.
We're also talking about split second situations. In a split second situation, if both you and a bad guy take aim on each other at the same time, pull the triggers at the same time, a single action would fire first.
