Ballast box or use something else?
   / Ballast box or use something else? #11
A backhoe is outstanding ballast.
It's pretty good for digging too.
I don't think the OP has plans for a backhoe. If so, he's getting the wrong tractor.
I personally never leave the backhoe on unless I need to dig with it. It really throws things out of wack on my hills.
No plans for a backhoe, if I had one I wouldn't have a lawn left because I'd be out digging holes all over.:laughing:
I'm thinking about just rigging up a bar to go through the 3-point arms and hanging some type of weight off it.
   / Ballast box or use something else? #13
It's nice living on flat land; I don't have to ever take my backhoe off.
I have seen a steel drum with concrete in it, used for ballast.
   / Ballast box or use something else? #14
Just for reference, I weight #230 and have close to 200 pounds of ballast in my rear tires. That's enough to move a full bucket of gravel or dirt without trouble but still, something as light as a landscape rake hanging off the three point is even better when I'm not in a tight space.
   / Ballast box or use something else? #15
Stevem70. My body weight sometimes helps and sometimes hurts. With a load on the forks or rock in the bucket it's good with me and the loaded tires also. . . Until I start going down an incline. Then my weigh shifts somewhat forward and no longer gives the rears that "bulk muscle" advantage :)
I found that creating a well located added weight on the 3 pt. That is neither wide or tall really eliminates my need to be as noticing of the incline amount until I get to "back it down" needs.
230# that's my goal by the way lol.
   / Ballast box or use something else? #16
I've always thought about getting a nice piece of rebar and going on craigslist list and buying up some olympic weight plates....
Another idea is to find a cut off of a ~18" diameter pipe, make some plywood forms to hold rebar in the center, and fill with concrete.
   / Ballast box or use something else? #18
I've always thought about getting a nice piece of rebar and going on craigslist list and buying up some olympic weight plates....Another idea is to find a cut off of a ~18" diameter pipe, make some plywood forms to hold rebar in the center, and fill with concrete.
I already looked into this. The used weights I found were kind of expensive and in the end it would be cheaper to buy a ballast box and fill it with cement. I think you best bet would be to hit up garage sales or auctions, the weight sets would probably go cheap at these places.
   / Ballast box or use something else? #20
Agreed. I recently switched over to R4's from R1's. Before I did the two or three plugged holes in each rear tire had leaked out all but about a gallon of liquid ballast. I kept my bucket close to the ground and my hand on the lever when working on even the slightest downhill:laughing:
I live on a hillside but the way things lay I'm usually going uphill with a loaded bucket.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
LOWRY 2020SB HD 7' DISC HARROW (A57192)
LOWRY 2020SB HD 7'...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
UNUSED 1RANCH 1RET13 HIGH END ELECTRIC TRICYCLE (A57192)
UNUSED 1RANCH...
2009 Kubota RTV900 4x4 Diesel Utility Cart (A55851)
2009 Kubota RTV900...
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
