How to choose a portable battery jump starter?
   / How to choose a portable battery jump starter?
Don't you think we could not find what you want by Google ranking.
I was just going to suggest Consumer Reports - as was just mentioned above. Also, usually always several reviews and comparison charts that you can find on Google ranking the best ones.
__________________________
Victor | Roadside Assistance
So you guys think what the best price of the jump starter is?
For me, the jump starter will be not so often used, so I hope it will cost less than $100.
   / How to choose a portable battery jump starter? #24
I seldom use my jump starer to start and engine. I use the built in air compressor a LOT.
   / How to choose a portable battery jump starter? #25
I am also very interested in a SMALL INEXPENSIVE jump starter.
Yes, for a car. a portable one better!
How big a car? What size engine: Gas or diesel?
If you decide to go with lit-ion batteries, read this review from Consumer Report about storing them in your car. They say all of the 10 models tested failed when temperatures reached 0 degrees fahrenheit. And they don't like being over 120 degrees, as in a parked car in the sun.
I'm following this thread because I would like to buy one someday and don't know which ones are worth my money.
Best Jump Starter Buying Guide - Consumer Reports
But I didn't see any Lithium IRON (LiFePO4) which do not have the tendency to explode.
LiFePO4 Portable Power Packs feature Lithium Iron Phosphate batteries, the safety Lithium Ion batteries on the market. Although slightly lower in voltage, LiFePO4 batteries are more tolerant to full charge conditions, allowing them to be stressed less. Despite its small size, the unit packs enough power to jump start your vehicle or charge your electronics
Not always when there is new technology.
If very low usage you will need to remember to charge it or set up a trickle charger or maybe a solar panel charger.
For the Lithium IRON (LiFePO4) units I've found 4.
LiFePO4 Portable Power Pack 200 Amp (1 MIN) $137.96
and it's big brother
LiFePO4 Portable Power Pack 400 Amp (1 MIN) for $212.39
The Schumacher SL1 Lithium Ion Jump Starter, Fuel Pack and Backup Power for $161
And to me the potential winner the Harbor Freight Viking Lithium Ion Jump Starter and Power Pack for $75.
Reading reviews about the Shumacher and the HF products it seems there is a percentage of immediate failures but if they work initially then they work well.
There have only been a few TBN'ers who have reported on the HF starter but if I recall correctly they worked well for a small car.
Hopefully more will chime in.
Their advantages are small, lightweight and don't go bang.
/EDIT the HF is on sale for $70 through 5/31
   / How to choose a portable battery jump starter? #27
Many of the jumpstarters also have a built in air compressor and LED light.
   / How to choose a portable battery jump starter? #30
As my title wrote, I need a portable jump starter.
But as a girl I am confused to choose which brand.
How can I choose a better one? Which brand do you use now?
Betty, let me end your confusion. I was in the same boat about a month ago. I was set to buy a more expensive, small, lithium ion charger. However, after investigating what was available at my local Walmart, I ended up with this jump starter https://www.walmart.com/ip/Schumach...p-Starter-12V-USB-Power-Supply-Black/54459186.
It has performed flawlessly. However, I opted to spend an extra $5.00 on an extended warranty. I highly recommend this product. I'm very happy with it.
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
2461 (A58376)
2461 (A58376)
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
