Gas powered portable welder, any thoughts on this one.
   / Gas powered portable welder, any thoughts on this one. #11
A single 384lb unit. $4600. I'd rather have individual units, but that's JMO. Easier to carry, easier to fix, easier to upgrade later.
   / Gas powered portable welder, any thoughts on this one. #12
I've had gas powered welders... These days, I use a pto powered generator, and plug my welder into it, also I can plug a compressor into it too.
One thing I like about using a genset is, I can run lights and also have someone running a grinder as I weld... NO switching a welder to AC and then back to welding!
SR
   / Gas powered portable welder, any thoughts on this one. #13
So far I've been very impressed with this engine drive welder.:cool2:
   / Gas powered portable welder, any thoughts on this one. #14
That got the Deutz in it Shield ? I have been lusting over the Vantage 300 with the Kubota but no way I can justify it and I can talk myself into a lot of stupid things ! My older Ranger 8 with the 16 hp Onan always does everything I ask of it.
   / Gas powered portable welder, any thoughts on this one. #15
Watch CL. There are usually some great deals to be had with engine drives. You might be able to score a Miller bobcat. Good thing with them is they are so heavy it's not likely to walk off unless they bring a tractor. I have a 250efi and it's been a great machine. 12kw I think
Brett
   / Gas powered portable welder, any thoughts on this one. #17
My friend recently purchased one of the last Vantage 500's available (phased out in favor of 600's I think).
He wasn't too impressed with the Deutz initially. It always coughed when starting and didn't run smoothly until it warmed up compared to the Cummins in his Vantage 400. He now has a couple of hundred hours on it and says it's a bit better.
Terry
   / Gas powered portable welder, any thoughts on this one. #18
I had a 5500w standby 240v portable generator and a Miller 130 240vAC, 200A rated stick. It would weld purlins using 3/32 6011s if it felt like it.
Got a 6500 240v and the same welder/rods welded just about anything i needed.
   / Gas powered portable welder, any thoughts on this one. #19
I paid $1500 for a used bobcat 225nt. Fairly low hours, 8000 watt generator.
Arc is nothing to brag about but it welds just fine.
I see them in the $800-$2000 range pretty often.
As others have noted, a 160 amp inverter running off a generator does a nice job too.
My Thermal Arc 161 burns 1/8" 7018 very nicely :)
It's also dual voltage.
   / Gas powered portable welder, any thoughts on this one. #20
I still have that old SA200 I traded for a couple of years ago. I had the machine work done and ready to put back together, but havent gotten around to it. While the sa200 is dc only, a lot of your hand grinders and drills will run off dc power as well as ac. as much as I have always wanted a portable welder, I just am not excited about having one anymore. Welding out in the field usually means crawling around under and wrenching on things. I just aint able to do that kind of work anymore. Its hard to get me to weld in my shop anymore. I really should get rid of the SA200 and let some young guy put it to good use.
SKID MOUNTED WATER PUMP (A55745)
SKID MOUNTED WATER...
Riding Mower (A55853)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
Electric Mobility Scooter (A55853)
Electric Mobility...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
