12 speed versus 8 speed transmission...is the 12 necessarily better?
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #11
the 12 speed op also includes added 3ph lift capacity. (at least on my 8540) if possible, i'd surely go w/the 12 speed. maybe go to the site & look @ the specs.
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #12
Not a kubota, but I went with a 24/12 trans for my Deere. It's a huge improvement over the 12/12 I had in the last tractor. Much easier to find the sweet spot especially when mowing. If it lightens up, I'll bump it up a hair, as soon as it gets heavy again, it's easy to slow back down. As mentioned, that upgrade also comes with several others benefits. If the 8 speed is a dry clutch and the 12 is a wet, that makes it a no brainer
Brett
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #13
The 12 speed option I think is about $1500.
It also includes a few other items including, Overdrive in H6, Hyd Wet Disc Brakes, Limited Slip Front Diff, and 540E PTO.
Just a few things to consider that you get by going with the 12 speed.
Stu
Those are all nice things to have available on any tractor, and any one of them might prove to be more useful than the extra gearing of the 12 speed. Are those options also available with the 8 speed tranny? Particularly looking at the Hyd brakes and Limited slip Diff.
rScotty
The only difference I am seeing, other than gear number, is that the 12's have hydraulic wet disc brakes, electro-hydraulic on the go 4WD, and 540/540E - along with a 16.2(61.5) pump capacity on the hydraulics versus 11.0(41.6). They're not saying that the 3pt has a greater lift capacity though. They both have a wet clutch and limited slip diff.
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #15
maybe a 12 speed with extra benefits....
if you were installing field tile / drainage lines.
if you have a lot of hills. (assumed pulling wide amount of different loads)
if you are running bat wing mowers, or any other wing'ed equipment. were you want faster raising/lowering of the wings.
if you running a FEL snow blower and wanting higher RPM via hydraulics.
if you are running any hay equipment / balers that rely more on hydraulics vs PTO to do something example round balers and opening rear gate.
if you are using a grappler or 4 in 1 bucket for FEL. more GPH / hydraulic pressure for quicker opening/closing.
TNT (top in tilt) on 3pt hitch or box blade/rear blade that is fully hydrualic for swinging and adjust the implement on the go.
boom mowers for ditch mowing alone roads. most likely need a higher GPM to make them more responsive.
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #16
I went with the 12 when I purchased a 7060 in February. I wanted the increased speed range, but really did it for all the other goodies noted in danisiri's post (esp the increased hydraulics). Love it.
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #17
I have a 12 speed on my New Holland. I have low, mid, and high with 4 on the tree. I love it. I spend most of my time in mid range when doing loader work and grading work. I go to low range when I am tilling the garden, bush hogging or really need to push something big. I use high range the least. Mostly for driving from one side of the property to the other or down the road to the neighbors house. But it is nice when you want to get somewhere quickly. Also like Buxus stated (increased hydraulics).
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #18
I will take the extra gears every time... My two most used tractors have 16 forward speeds...
I like having the choice of a couple extra gears above and below and close to the speed, I choose for the conditions I'm in, with what ever tool I'm working with.
SR
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #19
The wet "Clutch" on both is correct. The wet Hyd disc brakes only on 12 speed. The limited slip on both is correct. The 12 speed has limited slip "Front axle" which the 8 speed does not offer.
You can order the 540e PTO on the 8 speed which is around $1000. So if your going to spend $1000 for the 540e PTO why not spend the extra money and get the 12 speed.
I have had the 8 speed on a M5040 and M6060 and really like the extra gearing on the 12 speed in my M7060.
Stu
   / 12 speed versus 8 speed transmission...is the 12 necessarily better? #20
rScotty
No. Only the 540e PTO is avail on the 8 speed.
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
Goosen Bale Chopper (A51573)
Goosen Bale...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
