JD 1050 rear Hydraulic lift problems
   / JD 1050 rear Hydraulic lift problems #1
Billwalk
Raleigh, NC
JD 1050
I have a John Deere 1050 and the rear hydraulic lift is jerky. If you ease the lift arm up the lift doesn't do anything for a few inches then it jumps up. Is this an adjustment I can try? If so , where is the adjustment?
Thanks
   / JD 1050 rear Hydraulic lift problems #2
Welcome tomTBN
How long since sump screen was cleaned & hyd filter changed?
Welcome tomTBN
Im not sure. Thank you for the picture. I will check that and see if it helps. I bought the tractor used and I just need to go through and change all the filters.
I am going to give that a try. Thanks!
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
