Rim Guard dealers in Eastern PA, western NJ
   / Rim Guard dealers in Eastern PA, western NJ #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
Well After having moving about 80 yards of dirt the past weekends, I am ready to load the tires.
Does anyone know where some dealers would be near me? And what is the going rate for rim guard?
It is looking like 102 gallons I am going to need. Do you think it would be worth while to do the front tires too?
   / Rim Guard dealers in Eastern PA, western NJ #2
If you call the Rimguard company, they can give you a list dealers in your area.
   / Rim Guard dealers in Eastern PA, western NJ #3
beat juice = RV anti freeze (not toxic) (what i am using)
wind shield wiper fluid = another fluid folks use
i forget the other one = salt = rusting out rims (stay away from is recommendation)
would just load rear tires with a fluid. from picture / model listed in profile. you only have 2WD tractors.
with above said. i got tired of running over thorns on front tires and getting leaks. and filled the fronts with "green slime"
google "gemplers tire valve" it makes life so much easier filling tires with fluid.
if you have a 12v sprayer (make it a simple hand wand, to other). get handful of parts needed to connect it to gemplers tire valve. and makes for nice quick filling, just keep an eye on pressure so you do not over pressurize the tire.
if ya get down to it. you might find a cheap 110v sump pump at local hardware store on sale. you do not need much GPH nor pressure. even a cheap pond pump. though prefer using the sprayer, due to already had a container and pump. and less messy for me. and i can use sprayer for other things.
checking air tire pressure with fluid filled tires. can be messy, and can also rust out / cause sticking of generic cheap little air pressure gauges. they sell more expensive gauges to handle fluids.
i also cheated, the valve stem core tool i had was bent. so i needed a tool to remove the valve core for filling tires with fluid. so green slime already had tool that came with package thing. it was an excuse for green slime, but has worked.
if they would answer the phone or email back, that would be great
Rim guard is beet juice, not RV antifreeze
And if I Went and bout 120 gallons of RV anti freeze it would be about $450
then there would be all the time and buying things that I probably would never use again
While 120 gallons of Rim Guard INSTALLED will be about $455(3.25 a gallon and $65 labor)
Also my 260c is 4wd And If I get flats by running over thorn, then my 16ply and 12ply tires are junk
   / Rim Guard dealers in Eastern PA, western NJ #5
Have you tried Snyder's in Tamaqua ?
Rim guard finally called me back. A place in Allentown is the closest
   / Rim Guard dealers in Eastern PA, western NJ #7
What's the place in Allentown ?
Joes battery and tire
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2019 Caterpillar 966M Articulated Wheel Loader (A51691)
2019 Caterpillar...
Case International 3450 Round Baler (A51573)
Case International...
JOHN DEERE 9520 LOT IDENTIFIER 266 (A53084)
JOHN DEERE 9520...
HYSTER STRAIGHT MAST FORKLIFT (A51246)
HYSTER STRAIGHT...
