ford 3610 removing fuel pump seems to be stuck
   / ford 3610 removing fuel pump seems to be stuck #1
stevebb1
stilwell kansas
ford 3610
Hi all and thank you for stopping in.
I'm removing the fuel pump and replacing with a new one but it seems to be stuck to whatever it goes into .. which is where I put oil into the tract or and I can see when I look down into the oil filling hole (sorry I don't know the proper terms for this stuff) . .. but anyways I can see a gear in there is moving around when I move the fuel pump around .. and obviously that is what the fuel pump is stuck on ...
Another way to describe it is the fuel pump goes into a hole but when I try to take it out there is a gear stuck on it that is bigger than the hole the pump went into .. so how do I get free from that gear? Or is that the problem?
so can you guys tell me where I should go from here? And please don't tell me to hire a mechanic, tried that and if it had worked out well .. I wouldn't be here now.
I have another ford tractor that I steal parts off of .. and I tried taking the fuel pump off of it and it is acting the very same way, like its stuck with that gear on it. So I suspect then that I haven't gone far enough to get the fuel pump free .... but I can't figure out what it is that I need to do to solve my problem. - or they're both screwed up in the same fashion.
Thanks again for your input.
Okay I figured out I needed to take off the cover of the area where I put in the oil and then there are 3 bolts still holding the fuel pump in place.
and I see the gear is suppose to be loose to an extent (or that was my conclusion) so now I am just waiting on the fuel pump to get here. :)
   / ford 3610 removing fuel pump seems to be stuck #3
The trick to this is.. ask BEFORE starting a project like this.. and its called an INJECTION PUMP..
Do you have the SIMMS PUMP or a CAV pump?? On the Simms, the injector lines come off the pump, in a straight line.. The CAV are in a circle.
Why did you get ANOTHER pump?? Unless yours is seized, it could have been rebuilt..
   / ford 3610 removing fuel pump seems to be stuck #4
He has a CAV pump. "Here" it can be less expensive to buy and install a repop CAV pump than have a pump shop "rebuild" an OEM CAV rotary.
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
CATERPILLAR 303.5C CR EXCAVATOR (A51242)
CATERPILLAR 303.5C...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
