Deere Dude
Elite Member
- Joined
- Feb 10, 2011
- Messages
- 3,886
- Tractor
- John Deere 3720
Cars operate totally different than tractors as far going up hills. With cars you can downshift and just step on the gas and away you go. With tractors on larger hills make sure it is wide open throttle and if you see you are slowing down you will have to stop and shift down a gear, then crank the throttle back up. If it still slows down unacceptably you need to stop and downshift to a lower gear, throttle up and away you go.
I had my wife drive my 45 HP 3 speed hydro tractor to the city dumps with me following with the truck and trailer. She got half way up the hill and I saw her slow way down in top gear and the motor wide open. I was sweating it because she didn't know enough to stop and put it in a lower gear, but luckily she made it over the top. If it was steeper or longer she would have killed the motor. I was ready to get right behind her to keep from rolling backwards.
I taught her how to drive the tractor on the flat but never dawned on me to go over the hill climbing part.
Another thing to think about if you have a 4WD tractor and have a big load to the bucket or even in the rear, you could lose traction and slide downhill if it is slippery unless it is in 4WD.
