Federal Judge Dismisses Suit Against 'Drone Slayer'
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #71
Malaysia Airlines Flight 370--turning off the transponder helped it disappear.
Bruce
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #72
Bruce
There's no proof it was turned off. It stopped responding, yes. But no proof it was turned off. Give the pilot the benefit of the doubt that some electrical catastrophe (fire) took it out until proven otherwise.
Here's a link to a very sensible theory of what happened, and I'm inclined to believe it more than anything else, again, until proven otherwise.
https://www.wired.com/2014/03/mh370-electrical-fire/
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #73
Turned off by the pilot, or turned off by a fire, or turned off by a power loss.
Bruce
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #75
His theory does make a lot of sense.
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #76
I consider myself a realist, not clouded by emotions. The pilot crashed that plane. No argument intended. Just stating my opinion.
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #77
As it was explained to me, there's two different radar systems in use. One can see almost all airplanes and determine distance and heading, but it can't determine altitude. The other sends out a signal that transponders recognize. When the transponder detects that second type of radar, it squawks (returns) a number that the pilot was instructed to squawk. Air traffic control keeps track of the altitude they told you to fly at. So, if your have a transponder, and they tell you to squawk 1234, and fly at 10,000 feet, that's how they "best guess" your actual altitude. They are essentially trusting you to fly at the altitude they told you to, but don't really have a great way to verify that you are, indeed, actually at that assigned altitude. Sleep well on that.... :laughing:
Here's a link that explains it better ....
Transponder (aeronautics) - Wikipedia
It looks like the secondary transponder often broadcasts the planes pressure altitude, so with a working transponder and no monkeying around, then the ground station will have a measured altitude to read.
Point taken though: Z is harder to measure confidently than X, Y.
Rgds, D.
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #78
That's cool. Very well could have happened that way, too. Until they find it, and IF the recorders are still readable, maybe the truth will come out.
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #79
Rgds, D.
I did not know that. Thanks. :thumbsup:
   / Federal Judge Dismisses Suit Against 'Drone Slayer' #80
I have better than a clue. I have facts, which I have cited twice.
You, on the other hand, have nothing more than an uninformed and incorrect opinion.
Cell phone jammers are in common use in movie theaters and concert halls. Do you never wonder how an event like a Kennedy Center concert can be held with nobody getting phone calls? There are many exceptions to the regulations you cite.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
7060 (A53421)
7060 (A53421)
2007 NLB Trailer Mounted Shell Side System (A53117)
2007 NLB Trailer...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
CONTACT INFO (A53084)
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
