Briggs 22HP els motor backfiring loosing power I am stumped.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #1
dirtyb115
Southwest Ohio
Hello all. I am stumped trying to figure out what is going on with my zero turn. Its a 2006 Dixon ram 50, it has a 22HP els Briggs motor. Up until Saturday i have had zero problems with it. This past Saturday I was mowing some overgrown grass and it started to back fire and lose power especially going up hill. It progressively got worse by the time i had finished mowing. First i replaced the fuel filter, no change. Then i changed out the plugs, no change. Next checked the valve clearances, They were all around .006. I adjusted them to spec, but still no change. Then i pulled the push rods, none were bent. Went through the carb and everything seemed okay. Did a compression check and one cylinder came in around 100, the other 110. Tried unplugging wire on each cylinder when running and each time motor would run noticeably worse. Not sure what to try next. Starts great, idles great and runs pretty good until under load. The exhaust seems a little louder to me, but not positive on that.
Anyone have any ideas?
Thanks!
   / Briggs 22HP els motor backfiring loosing power I am stumped. #2
Possibly a blown head gasket.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #4
   / Briggs 22HP els motor backfiring loosing power I am stumped. #5
Easy check- remove the flywheel nut and verify that the key is not partially sheared. You may need to check a couple of additional things under the valve covers. 1) look at all 4 valve guides and note if they are protruding from the head about the same distance or has one started to migrate. 2) Remove the spark plugs and roll the engine by hand. Compare the valve lift as you do, once again - they should be close to the same. Should you have a worn cam lobe, you'll know.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #6
I've had the key offset over half its width after an impact.
Bruce
Thanks for the reply. I forgot to mention in the first post that I also checked the flywheel key, it was fine. I also tried unhooking the kill wires and no difference and even cleaned out the muffler. I will take a look at the valve guides and and look at lift as well hopefully tomorrow. I went through the carb again today hoping i missed something but still doing the same thing.
Well, i think the mystery is solved. The exhaust valve on one of the cylinders is barely moving. Guess its time for a new camshaft. Not looking forward to pulling the motor out. Anyone have any tips on replacing one of these? I saw one video but they recommended having an oxy torch to get the bottom pulley off which i dont have. Hopefully pb blaster will work.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #9
Are you to the point of removing the engine? Hopefully your drive pulley comes off more easily than heating. Many of them do. MTD products of the last 10 years or so are buggers. Dixons, I dunno. If it comes to the point of using extraordinary measures on the pulley, do your homework on price and availability of a new pulley. PB isn't a slouch, but order a can of Kroil if you want great stuff.
Just ordered parts yesterday so plan on pulling motor early next week. Hoping clutch and pulley come off okay.....
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
2008 Ford E-350 Cargo Van (A51692)
2008 Ford E-350...
Honda Pioneer 700 NR (A53424)
Honda Pioneer 700...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
