Rust around fuel tank filler neck
   / Rust around fuel tank filler neck #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I have a 2012 model John Deere 5093E. There is significant light rust around the filler neck, chain that attaches to the screw on fuel cap and a small spring in the cap..Any idea what could account for this?
   / Rust around fuel tank filler neck #2
Moisture in your fuel
   / Rust around fuel tank filler neck #3
Too much rain or too many wash jobs.
   / Rust around fuel tank filler neck #4
Salt spray if out near a highway during winter in MN.. possibly.
Probably just condensation but I've never seen it this bad on such a new model (2012) However, the tractor set for a year without use before I bought it and I suspect the fuel tank was near empty..
   / Rust around fuel tank filler neck #6
:D Not likely salt in TX unless on the gulf maybe.
   / Rust around fuel tank filler neck #7
I had this issue on 2012 model . Replaced cap under warranty. I removed chain as it appeared to be source of most rust. I didn't like chain anyway. I turn my cap facing up on fender when refueling
   / Rust around fuel tank filler neck #8
I have a 2014 5065e with the same issue, looked through john deere parts and the threads in tank did not have a part number or breakout. Does anyone know where to get a replacement thread insert.
   / Rust around fuel tank filler neck #9
I looked at my box that parts came in. The black plastic cap is part number AL 113086. I have another parts bag with part number L 80418 on it. I think that is the threaded filler neck. There is a rubber o-ring under filler neck (which threads into plastic tank nozzle). The o-ring seals between metal neck and plastic tank. My tractor is a 2012 5065e. I doubt the tank changed. The o-ring is part number L 112337.
Mine is also a 2012 model..I think I too will remove the chain..It's about to rust off anyway :)
UNUSED COYOTE AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED COYOTE...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
APT Air Jack Hammer (A59213)
APT Air Jack...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
1995 Kenworth (A57148)
