JD Kholer 23 HP Blown Head Gasket or Broken Rings?
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #1
georgia088
Member
Thomaston, Georgia
Mf 30?
I appreciate any help that anyone can give me. I have a 23 HP Kholer engine. It has been smoking a grayish blue smoke intermittently for several hours of use.
However, it got really bad this last use. I pulled it in garage and begin tearing down. I am assuming (and hoping) its a blown head gasket. I tore it down and looked at the head gaskets on both sides. I can't visually see anything wrong with either head gasket. However, I see a pretty good bit of oil in one cylinder and the spark plug was soaked with oil. Both cylinders feel great and smooth. If it were a broken ring wouldn't it scar up the cylinder pretty bad? Could these issues be caused by a valve seal?
Thanks.
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #2
Is this a water cooled engine?
What tractor is it in?
Richard
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #3
In my experience, broken rings do not usually score the cylinder bore. Possible? Yes.
Bad stem seal(s) can indeed cause the problem you see. That is why a leak-down test
is done before you remove the head. Note that the head gasket also likely seals some
high-pressure oil galleries.
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #4
Overhead valve? probably rings or valve guides on an air cooled engine. If water cooled you would see more white smoke from coolant and wet not oily cylinder walls, unless one of the oil passages broke through the gasket but not likely.
It is air cooled. It is in a jd L130. So although the cylinders seemed smooth as can be it could still be the rings? I'm not sure that I know exactly what you mean by the stem seals? Is this the same as valve seals?
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #6
It doesn't take much to pressurize the crankcase. The gasket failure may be thinner than a pencil lead. They can vent even to the oil return hole. At this point you may as well get 2 head gasket kits and reseal it.
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #7
The part of the valve that goes thru the head is the valve stem. There is clearance between the stem and
the valve guide. The valve stem seal keeps too much oil from getting thru the guide into the
combustion chamber. If you remove the valves for the affected cylinder, you can see if they wiggle
too much inside their guides, and if the seal looks bad.
   / JD Kholer 23 HP Blown Head Gasket or Broken Rings? #8
I've not personally seen a Command with worn out guides. But then again, I've seen a Courage twin with bad cylinder wear. Goes to show anything is possible. You could rock the piston crosswise in the bore. I suppose you could also change the breather plate gasket whilst you are there. That has been updated at least 4 times. The only problem I've had is an external leak myself. There are reed valves too which strangely will break once in a blue moon.
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
1274 (A50490)
1274 (A50490)
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
