G6200 HST Hydro Release
   / G6200 HST Hydro Release #1
Speckred17
Waco
Kubota G5200, Sears Professional 27 HP, John Deer 260
Hello all,
I have an issue with my G6200 hst and need to load it on my trailer to get fixed. Is there a release valve somewhere for the hydro? I can't find anything anywhere. I do not want to winch it on my trailer without releasing that.
Thank you for your help.
   / G6200 HST Hydro Release #2
Hello all,
The operator's manual (Section 5) for both geared & HST states: IMPORTANT: DO NOT TOW THIS MACHINE. Damage to transmission may result.
Not sure how to read that - does it mean never push the tractor, even a few feet, or don't tow it behind your pickup on the interstate like a trailer? I never could find any kind of release like the little pull/push one that our Craftsman had. Not wanting to ever have to fix that Eaton HST, I have tried to observe the operator manual's advice.
Over the years I have rolled it forward (engine & parking brake off) a few feet with no noticeable problems.
I once had to move it from out of our field to our shop, where I could work on it. I did that by pinning the front axle pivot with wood wedges, securing the steering wheel and towing the tractor, backwards, by lifting the rear wheels off the ground with a boom pole on a larger tractor. Not sure if that was really necessary, but it worked.
For winching it onto a trailer - consider bringing a suitable dolly & floor jack. Get the tractor in position behind the trailer, lift the rear end with the jack & put the dolly under the rear tires or rear frame. With the tires off the ground, you should be able to winch away.
Thanks for the reply. That is what I am seeing. I have looked all over for a release. On both my craftsman's and my John Deere, there is a release so it rolls freely. Was hoping I could find that with this one.
   / G6200 HST Hydro Release #4
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
Toro Mower (A50324)
Toro Mower (A50324)
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
