Briggs 22HP els motor backfiring loosing power I am stumped.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #11
Time to soak!
Time to soak!
Finally got a chance to work on it tonight. Guess I was lucky the clutch and the pulley both slid right off on their own. I did soak them for 2 days. Motor is out, hopefully will get a few more hours this week to get inside and replace the camshaft.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #13
Thanks for posting progress reports... it is much appreciated and provides leaning opportunities.
Had some more time last night to work on the motor. Watched a youtube video on how to replace briggs and stratton camshaft (guy with fake teeth). Video was helpful. I didn't have any real problems taking apart other than I could not get the camshaft out until I removed the pushrods. As you can see in the pictures the one lobe is worn pretty bad. Wonder why only one started to wear? Hopefully this will fix everything for a while. Motor is reassembled and just needs to be bolted back onto the mower. Hopefully will have time this evening. :thumbsup:
Finished hooking everything up tonight. Runs great, problem solved, thanks everyone!
   / Briggs 22HP els motor backfiring loosing power I am stumped. #16
Good Deal and just in time for summer mowing.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #17
that sucks hope all goes well i wonder why that briggs broke
   / Briggs 22HP els motor backfiring loosing power I am stumped. #18
Well, the one lobe was hardened on Friday afternoon and it was almost beerthirty.... It happens on the singles and twins alike. Not a lot as there used to be I think. Kudos on a job well done.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #19
camshafts are a continual problem in intek and Platinum series.
number one on the list.......change the oil regular and frequent.....Mow up and down hills........not side hill
use a high grade 30 weight sae oil use nothing else.......any multi weights will fry your engine sure as the day is long.
   / Briggs 22HP els motor backfiring loosing power I am stumped. #20
Definitely sounds like you are coming from professional experience.
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
HLA 48in. Tractor Loader Forks (A51691)
HLA 48in. Tractor...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
