Anyone ever use "Rusty Metal Primer" as a final finish?
   / Anyone ever use "Rusty Metal Primer" as a final finish? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Wife wants her small metal porch table painted the exact same color as Rustoleum Rusty Metal Primer. How about I just use that primer as a final finish? Has anyone ever done that to know how well it will hold up?
   / Anyone ever use "Rusty Metal Primer" as a final finish? #2
Primer is porous and allows moisture to get through it. It also wears of quickly compared to paint.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #3
Primer is a great cover and sticks well to paint. But not protect the material you've spayed it to long term.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #4
I have been using it lately on hay feeders and gates. Seems to hold up well enough. The goats scrape and rub the paint off whether it is primer or paint.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #5
You could try the primer route, but cover it with a flat clear coat? That might work, or atleast be worth a try
Brett
   / Anyone ever use "Rusty Metal Primer" as a final finish? #6
You could add a couple coats of clear finish over the primer for protection.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #7
Any time I left metal with a primer coat I got rust. It's not supposed to be the final finish.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #8
Prep and paint the table with the primer, put it on the porch and say "Now it's ready to paint".
See what happens......
If the paint doesn't hold up, treat the bad spots, reprime and paint.
If the porch is covered, you're probably not going to touch that table again except when you grab your beer off it
   / Anyone ever use "Rusty Metal Primer" as a final finish? #9
+1 :thumbsup:
Primer will not give the best corrosion protection.
If the O.P. wants a one coat finish, which is a compromise, buy a product that is designed for that.
   / Anyone ever use "Rusty Metal Primer" as a final finish? #10
as previously suggested...the most logical solution is a clear finish top coat...Rustoleum makes several clear finishes...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
