Loss of power, fuel starvation, I think
   / Loss of power, fuel starvation, I think #11
Unfortunately no filter in the tank and just about anything like the wasp can make it to the lift pump. As mentioned, some members have put an in line filter after the tank and before the lift pump.
   / Loss of power, fuel starvation, I think #12
I had some black crap in my tank which plugged up a fuel filter on me. I don't know if it came in the tractor when I bought it or was in a fuel can of fuel.
   / Loss of power, fuel starvation, I think #13
Likely neither. It was likely algae. Not green but black. Diesel bugs. They can start any time there is moisture in your fuel from condensation. Their food is the fuel itself, and they grow and multiply.
Recognizing diesel fuel algae
   / Loss of power, fuel starvation, I think #14
I wasn't aware of this, thanks for the info. My tractor has been fine ever since that happened.
I have now put another 640 hrs on it, (1380 total) and never had the issue again.
   / Loss of power, fuel starvation, I think #16
Maybe it was just some "crap" of some kind. Because usually when you get a case of "algae" it usually doesn't go away easily. Anyway keep on eye on it.
   / Loss of power, fuel starvation, I think #17
May 2017: Kioti DK40 SE. Same problem. Loss of power. Seemed to be fuel supply. Read mulitiple posts. Added fuel conditioner, changed fuel filter etc etc. Then removed various fuel lines to fuel pump, filter, injector pump and found a wasp sticking out of the line from the tank into the fuel pump, before the fuel filter. Voila. All is good.
Same thing here, TWICE, on my Yanmar. Floats around in the tank, and eventually blocks the small hole coming out of the bottom of the tank.
When your fuel flow seems low, pull the line off the tank and physically check the amount of fuel coming out of the tank. Low ?.....push a skinny screwdriver, or something, up in the fitting and see if you don't get hosed with fuel. You found the problem.
First time, tank off and washed out. Pain to remove tank.
Second time....cheap Home Depot inspection camera, and a long set of 'grabber' tongs to remove the offending wasp in the tank.
NOW, every time I fill up the tractor, I bang the hose-from-tank nozzle upside down against the wall, because that is the only point of entry I can figure for these wasps. I don't drive around with the fuel cap off, and there is a 5 micron filter between the tank and hose....so they HAVE to be getting in the nozzle is my thinking.
   / Loss of power, fuel starvation, I think #18
Actually, they don't. My 40hp Yanmar has only about a 1/4" tank outlet, and wasp in tank blocks it well enough to cut fuel flow to near nothing.....not nothing, because enough will dribble down to fill up the filter bowl and let the tractor start again in a minute or two....only to die again unless the wasp floats off the fuel outlet.....then it floats back over again later.
It will drive you nuts, I'll tell you that. Have you changing fuel filters, solenoids, and so on, for one tiny critter.
   / Loss of power, fuel starvation, I think #19
Suggestions to add another filter between the tank and the fuel pump are nice but the wasp could just as easily come thru the tank and get stuck as it enters this new filter blocking fuel flow.
   / Loss of power, fuel starvation, I think #20
These "bugs" grow at the interface between the Diesel fuel and water at the bottom of he tank. And there will ALWAYS be some water at the bottom of the tank, thanks to temperature cycles and condensation. This is a bigger problem with boats, tractors, etc that tend to sit unused for extended periods. The solution is to use a biocide fuel additive, Amazon lists several. I have used Biobor successfully for several years.
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2016 Freightliner Tandem Bucket Truck, VIN # 1FVHCYCYXGHHA5025 (A51572)
2016 Freightliner...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
