3-Point Hitch John deere 301 (1020) cat 2 lift arms
   / John deere 301 (1020) cat 2 lift arms #1
jcharley
Member
Missouri
71 John Deere 301 (gasser)
I'm wondering if there are any recommended aftermarket 32.5" cat 2 lift arms for my john deere 301. (Similar to 1020) I currently have cat 2 arms but they are very short. I recently purchased a drum mower and can't hook up the pto with the short arms.
I know the factory part numbers are ar77530 or AT19849. However they are $200 each used.
Thanks,
Jeff
   / John deere 301 (1020) cat 2 lift arms #2
Another option is shorten the PTO shaft...
I'm hoping to avoid that if possible. The mower just doesn't seem to sit properly with the short arms. The only thing I use the short arms on are my brush hog. Everything else's uses the 32.5 class 1 arms. If I upgrade to the 32.5 class 2 arms I would just need to use bushings for my other implements and no longer have to swap out the arms.
   / John deere 301 (1020) cat 2 lift arms #4
Just go to a CAT 1 pin on the implement. Never in my life heard of changing lift arms unless it broke .
   / John deere 301 (1020) cat 2 lift arms #5
Ditto on changing draft pins to Cat l
Thank you for the advice. The draft pins are solid welded through the frame. I was able to find a salvage yard that was willing to ship me a used set for $250.
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
CATERPILLAR 926M WHEEL LOADER (A51242)
CATERPILLAR 926M...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
