Um what?...Never change the oil?
   / Um what?...Never change the oil? #21
the science behind it is, from the add mark to the full mark replaces 20% of the oil volume, and that is sufficient to replenish the additive package in the oil, coupled with the fact that most people don't change their oil on a regular bases, if at all. The engine is rated for 125 hours of operation which for the average person equates to like 10-12 years of operation.
The catch is the spark plug and air filter have to be serviced on a regular basis to prevent oil contamination. The problem is the people that don't change their oil, also don't service the air cleaner or spark plug.
Thank you for this. I can't find much documentation or explanation on this whole "never change your oil" thing for small engines. I noticed that Troy-Bilt had a similar label on their walk behind mowers in my favorite orange big box store.
   / Um what?...Never change the oil? #22
Sounds to good to believe. :confused3:
They don't change the oil for many jet engines. They use synthetics, good filters and analyse the oil on a regular basis replacing additives as needed.
   / Um what?...Never change the oil? #23
If it's a 2 cycle engine you don't change the oil.
   / Um what?...Never change the oil? #24
We had a Suzuki motorcycle that had a fuel tank and oil tank. It was 2 cycle and mixed it's own oil. I think there are several engines that do this but have had only one. Fill with gas and check the oil then add if it's getting low.
   / Um what?...Never change the oil? #25
The details of this engine was discussed in my Briggs and stratton update school in the fall of 2014 as this was a new engine/concept for the 2015 model year. That same year they eliminated the 5 hour initial oil change on engines with an oil filter.
   / Um what?...Never change the oil? #27
/www.briggsandstratton.com/na/en_us/innovations/push-mowers/exi.html NOTE what Alex13 says under the reviews.
   / Um what?...Never change the oil? #28
Many people never bothered changing the oil in older mowers. Including (as confessed here) people who definitely knew better.
There will still be some "What, I have to check oil on these things ?" from some people. My neighbour came to see me one Sunday, as he was out of oil - never changed his push-mower oil, and he let it get low enough that "the engine was really stiff to pull". He was a great guy, so I didn't mind giving him some oil, but I did shake my head...... same age as I, grew up servicing his own vehicles, with his Dad building concours quality restorations, including engines.....
I think this is smart marketing by Briggs.
I'd still be changing my oil in this Gen of Briggs - perhaps just a little less often than I do now. I'm curious if they've really done much with the air-filter design; the one on my easily 10 years-old Briggs engined Craftsman mower already had a decent "automotive" style gasket on the air-filter.
Rgds, D.
   / Um what?...Never change the oil? #30
Rgds, D.
I suspect your older mower has the square filter on the side with the single bolt at the top to hold the cover on. The filter this engine uses is a press fit that is designed to eliminate dirt bypass around the sealing surface, and then has the main cover over the filter.
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
Sterling AT (A55301)
