CountyLine Post Hole Digger- BX25D-1
   / CountyLine Post Hole Digger- BX25D-1 #11
   / CountyLine Post Hole Digger- BX25D-1 #12
Smile ...........someone should come up with a reversible gear box for those emergency corkscrew situations , I have only done the long pipe wrench with helper pipe once , so careful use in clay is a must now. :D
Has anyone ever tried turning the PTO shaft backwards so that you get the mechanical advantage of the gearbox?
Is this possible?
   / CountyLine Post Hole Digger- BX25D-1 #13
Never crossed my mind, but probably would need to make a habit of running the post hole digger without the plastic sleeves on the driveshaft , so that one could easily find a spot on the driveshaft (triangle steel) to put a pipewrench and try to use the mechanical advantage of the gearbox by turning drive shaft in reverse. I would hate to try to use the end exposed parts of driveshaft (with plastic sleeves on) because those are the universal type joints and I would be afraid to break something there....but maybe there is a way ?
I'm curious as to what this means?
   / CountyLine Post Hole Digger- BX25D-1 #15
If you bind the auger bit in compacted soil, you can't pull it out of the hole, you have to manually reverse it like a corkscrew in a cork. PTOs don't spin backwards.
   / CountyLine Post Hole Digger- BX25D-1 #16
Disconnect the auger from the rest of the unit (ie, move the tractor away leaving the bit stuck in the ground). Use a long pipe wrench to turn the auger backwards.
I don't think you could use the the gearbox to your advantage because not only would you need to turn the PTO shaft backwards (like, get a splined socket and crank it while supporting the PTO shaft; or disconnecting the shaft completely and attaching something like a T-bar to the joint where the PTO connects to the gearbox?), but you'd also still need to counter the torque like the PHD frame does - without the frame, the gearbox would spin on top of the auger instead of the auger spinning below it. You may be able to do this perhaps by parking a truck or tractor next to the gearbox perhaps after clamping a long board to both so that the gearbox is essentially fixed to a large object, which would force the auger to spin instead when you turned the crank.
Bolting a long bar, maybe like a 2" square tube (or a chainlink fence end post, though round), to the top of the auger and having 2 people turn it by hand is probably the simplest and quickest way to extract a stuck auger.
   / CountyLine Post Hole Digger- BX25D-1 #17
I think they mean leaving the auger attached to the tractor, disconnecting the PTO shaft from the tractor, then turning the PTO shaft backwards while lifting on the 3 pt. I would imagine you'd have to turn the pto shaft with either a long bar through a u joint (probably not a good idea) or with a wrench on the shaft itself.
I think they mean leaving the auger attached to the tractor, disconnecting the PTO shaft, then turning the PTO shaft backwards while lifting on the 3 pt. I would imagine you'd have to turn the pto shaft with either a long bar through a u joint (probably not a good idea) or with a wrench on the shaft itself.
Thanks... I got it now.
2015 CATERPILLAR 272D2 SKID STEER (A52707)
2015 CATERPILLAR...
2015 Autocar Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2015 Autocar...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
