End of warranty inspection by dealer
   / End of warranty inspection by dealer #1
Danger18
Calhoun, GA
2015 LS XR4046HC
Compression. Fuel pressure. Hydraulic pressure. I'll be going out of warranty with less than 300 hours soon, and am wondering what else I should have inspected prior to 2 year warranty expiring. I have a 2015 xr4046hc. Only somewhat common issue I've seen on here is the hubs which seem fine.
   / End of warranty inspection by dealer #2
Great idea....worth every penny to have this done. Will put this on my to-do list.
   / End of warranty inspection by dealer #3
I'd break those hubs down and look at the bearings, but that may be expensive for them to do. Mine seemed fine also, then the next day they were toast. Inspect that sub-frame in the front carefully for cracks in front of the engine. Also, take the driver side cover off the console and look at the shaft that connects to the forward-reverse lever. There is a metal flap attached that butts up to a magnetic switch when it's in neutral. Make sure that the bracket that the switch is attached to isn't bent or cracked. If it fails, it'll take a week to figure out why the tractor won't start. With as few hours as you have, there probably won't be any problems. I had over 300 hours on mine within a year of purchase.
   / End of warranty inspection by dealer #4
Get emissions system checked.
   / End of warranty inspection by dealer #5
Emissions is currently covered by a 5 yr / 3000 hr warranty, so I wouldn't think that would be a concern at the 2 year point (unless that was a change in the past two years).
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2016 INTERNATIONAL MA025 BOX TRUCK (A52576)
2016 INTERNATIONAL...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2007 PETERBILT 379 SLEEPER (A52472)
2007 PETERBILT 379...
