3016 slow following 50 hr service
/ 3016 slow following 50 hr service #1
Dsimonl
Member
Portland OR
2014 Mahindra 3016 HST
Our 3016 HST just came back from the dealer. It seems really slow, and gutless following the 50 hr service - like the engine has no power. Forward speed is just a crawl. What could they have done? They are over an hour away, so not convenient to return.
/ 3016 slow following 50 hr service #2
HST or Manual?
The most likely- if the throttle increases without load- is a fuel obstruction. The most common spot is in the tank where the fuel line comes out at the bottom.
If it's a HST it could have the wrong fluid and or filter that is causing a lack of pressure and or volume to "power" the HST. Other filters will "fit" in the HST filter location which may have happened.
It should be a relatively easy fix.
/ 3016 slow following 50 hr service #3
I ran into this once when I got diesel contaminated with water in it. Take a look your fuel filter/water separator. It should be clear (not cloudy). Drain it and inspect the filter of course. Disconnect and drop the inlet line into a container and turn the key 1-click so the fuel pump starts to prime to see if you get fuel.
I'll have to check the invoice again. I think they replaced the FF. Actually, for $629, they better have!
/ 3016 slow following 50 hr service #5
Holey-schmoley! There is no shame in doing the service intervals yourself, and then take you and your whole family out to a VERY nice dinner. :thumbsup:
BTW, is your dealer in Newberg or Salem, to be an hour from you?
/ 3016 slow following 50 hr service #6
If I'd paid that much I'd pick up the phone and have them come get it and make it right on their nickle.
yes, I complained. They removed 2 hours ($220) from the invoice. They claim $336 was parts and shop supplies.
/ 3016 slow following 50 hr service #8
4 filters, hydraulic fluid, engine oil and some grease. That's at least $200.
/ 3016 slow following 50 hr service #9
I would have them come fix it, knocking off $220 dollars from the bill does nothing to get your machine running. If you took it to the dealer yourself I would load it back up and get it back to them. Its well worth the time to get it running good again. You paid for it, they should make it right.
/ 3016 slow following 50 hr service #10
I know if it was my dealer they would be coming out with a rollback to pick it up. Demand they come out and either fix in on site or take it back to the shop.
Update: Browneyesvictim was most likely correct. We filled the tank with fresh diesel and mowed with it for a couple of hours. The sluggishness seems to have cleared itself. Engine and hydraulics are once again responsive. Thanks! We love this tractor.
/ 3016 slow following 50 hr service #12
Maybe had some air bubbles in the fuel system due to the filter change. Glad it worked out for ya.
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
