trailer electric star adjuster how to measure length?
   / trailer electric star adjuster how to measure length? #1
boggen
Elite Member
Trivoli, IL
SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
heard some dragging, pulled wheel. and found out the spring and the star adjuster broke and came off and both got mangled pretty good.
went to see what i could find and have different measurements for star adjusters.
how determined what length i need? 7", 10" 12"
never realizing it before, when trying to find above came across below video. and who ever built the trailer, put the magnet on top. and the star adjuster as well on top, and the lever for the magnet is facing backwards not forwards, and the short pad of the 2 drum pads is facing rear ward.
will be pulling all 4 tires and brakes and swapping them side for side.
glad i decided to take other side off tonight, need another spring as well *doh*
trailer front tire right side.jpg trailer rear tire left side.jpg trailer drum spring 4 inch.jpg trailer star adjuster.jpg
and to confirm looks like i will need to pull all 4 brakes off the axles and swap everything around.
   / trailer electric star adjuster how to measure length? #3
Time for new backing plates. Cheaper than partsband you will be doing it right
   / trailer electric star adjuster how to measure length? #4
Time for new backing plates. Cheaper than parts and you will be doing it right
X2!!!!
I went through that from advice given on this forum and some prodding from members. I would do the same thing again. You get new magnets, springs, shoes and whatever else that just needs to be put on. The whole assembly was about the same cost of just the magnets, if I recall correctly. It was a no brainer for me.
   / trailer electric star adjuster how to measure length? #6
Another vote for just getting new backing plate assemblies. They were a lot cheaper than buying the individual brake components and I do believe it was a lot faster replacing the assembly rather than installing all brake parts. Five bolts, two wires, repack the bearings, replace the hub and tire, adjust the new brakes, you're done.
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
1049 (A50459)
1049 (A50459)
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2014 Ag Spray Schaben Sidedresser (A52128)
2014 Ag Spray...
Gehl 1870 Round Baler (A50514)
Gehl 1870 Round...
