rustydollar
I'm going to power this compressor up with the 18 HP Perkins diesel that came from a Toro lawn mower, the compressor was a gift. It puts out 35 CFM and it's a two stage capable of 175 psi.
Compressor/drive system is a process of calculations.
A lot of compressors use the same pump with different motors/engines.
The larger the drive HP the larger the drive pulley.
Everybody has seen a compressor that tries to stall out because someone put too small a power unit with too large a drive pulley!
Look up the pump/HP rating and it should give pulley size.
hmmm...
Horsepower required to Compress Air
looks like about 3/16 hp/cfm @ 175 psi = 187 hp @ 35 cfm
I don't think that's right (either the formula or your calculation) as 105/16 (3/16*35) works out to a little over 6.5 horsepower and there is no way that can be right as a compressor that can put out 35CFM@175PSI is a beast and would have a much larger motor than a little 6.5HP one.
Aaron Z
That sounds like a great combination for an engine driven pump!
Why would anyone need 175 psi in any situation short of industrial I can not imagine.
120 psi fills all my shop needs and still I use caution around air wands and the like.
I suppose if one needed to optimize storage, the higher pressure would be welcome. Or if there were a certain application that needed the higher pressures.
From my experience with air equipment (aviation background) It is VOLUME at around 120psi that does the lions share of the work as far as hand tools and shop equipment goes.
Line losses are always an issue, and they can not be made up by running higher pump pressures "safely".
