1995 toro wheel horse with a vanguard engine
   / 1995 toro wheel horse with a vanguard engine #1
Chette
Madison Heights, Va
Toror Wheel horse Lawn Tractor 28Q777-01608 Briggs and Stratton Vanguard Engine
I am rebuilding a Briggs and Stratton Vanguard 15.5hp 28Q777-016801 Engine.
In the sump engine case there is an oil seal which needs replacing.
How do I get the old oil seal out and the new one in?
here is the picture of the seal bottom out side of the sump case that attaches to the crank case
please respond here or email me ASAP.
Chette
   / 1995 toro wheel horse with a vanguard engine #2
Does it look like you can you punch it out from the other side?
   / 1995 toro wheel horse with a vanguard engine #3
There are a number of youtube videos showing ways to remove oil seals.
   / 1995 toro wheel horse with a vanguard engine #5
With the sump off you could probably just pry it out with small bar. When they are assembled, you can pop a small hole in the edge with an awl- then turn in a sheet metal screw and 1) pry it out via the screw or 2) let the screw bottom on the pan boss and push it out that way.
5- RIGID 65-R THREADERS (A53843)
5- RIGID 65-R...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
