Moving to the 1st world
   / Moving to the 1st world #101
Do you mean 396 kV AC? Which isn't a size just a voltage they transmit at. 138kv is popular around here, with longer and major tie points being 345 kV. Transmission lines are higher to use smaller wires, and copper losses.
Populated areas connect smaller stations with 24 or 34 kV, sub-transmission. Rural is transmission stepped right down to 12, 8, or 4 kV.
The size of the PV plant is 396 kW rated power (After conversion from DC to AC). At what voltage it connects to the grid is unknown to me but I would suspect the output from the inverters is three phase.
   / Moving to the 1st world #102
Based on just that factor, California should have the lowest costs in the USA.
Utility rate comparisons - Electricity
(Sorry OP.... at least that link let's you compare Canadian options :drink:)
Manitoba has lots of empty space, yet their rates are half of Ontario's. To make things worse, ON rates have gone up at least once, and probably twice since that survey was done.
Customer density vs. geographic distribution is only one factor of many.
Rgds, D.
I got you, it generates 4 MW. Which is a tiny plant. Lots of infrastructure for something so small, if owned by a utility.
For power it we usually go MW, voltage stays with kw, because the the round off makes a difference, we have 115 and 138 kV so 1MV foundn't work.
There are some old 4 MW plants out there built long ago, often by a customer, and then mayb bought by a utility.
Most plants are mutlipe 500MW units. You have some smaller 17-150 MW peaking plants, usually gas. 17 would go in rural area. I only know of one. Most are bigger. Usually small stuff is built by mills.
In UP which is very rural, there are building 17 and 150 gas units, for back up power and voltage control. Even up there, they would not bother with 4 MW.
   / Moving to the 1st world #103
There are some old 4 MW plants out there built long ago, often by a customer, and then maybe bought by a utility.
Most plants are multiple 500MW units. You have some smaller 17-150 MW peaking plants, usually gas. 17 would go in the rural area. I only know of one. Most are bigger. Usually, small stuff is built by mills.
In UP which is very rural, there are building 17 and 150 gas units, for backup power and voltage control. Even up there, they would not bother with 4 MW.
It is all relative. 400 kW is small but our utility is also very tiny. BTW I commission control systems for steam turbines (and other rotating stuff) for living so I am familiar with power plants operation.
   / Moving to the 1st world #104
I'm pretty sure that Zimbo doesn't really care how big your power plant is.....
   / Moving to the 1st world #105
Are you electrical?
I am a start up engineer. I do the protection portion for generators, breakers, and controls. I don't do tuning, but I am involved with it a bit. I have worked in coal, gas, and hydro plants. I like work on stations, I like being outdoors and schedules are better, they don't come on in the middle of the night, and usually come on when they are supposed to.
400 KW still sounds extremely small. You are sure you got your zeros right?
   / Moving to the 1st world #106
Ya we got off track, but the questions also stopped. Hope he lets us know how goes, and his thoughts in choicing whatever he choices were.
   / Moving to the 1st world #107
Maine produces surplus electricity that goes into the southern New England grid. Our electric rates are based on - transmission (utility companies) and the source of electricity. The demand is greater in the southern New England area and Maine electric companies make money selling and producing for them. However, that drives up the cost of electricity for Mainers. In addition, we subsidize all of the utility projects and new construction to get electricity from Canada to Mass. Our utilities closed down the majority of the hydro we had in the state- years ago. It was cheap, but did not provide them with opportunities to borrow, invest, etc - cutting out a portion for themselves. (The more money that flows through the system, the more opportunity to dip in and have a drink!) It is all a scam. Now they don't want us to have solar - loss of profit.
- Nice analogy I came across.
The local supermarket says it should tax you for the tomatoes you grow in your garden because that results in a loss of revenue for them. ..... They would probably want to put a smart meter in your garden to check on the progress of your tomatoes, along with another one in your kitchen to collect a value added tax when you prepare them!
   / Moving to the 1st world #108
Are you electrical?
400 KW still sounds extremely small. Are you sure you got your zeros right?
I am also startup engineer. I do mainly compressor protection, associated process control, steam turbine speed, generator control etc. I am currently retired but still do several jobs per year for my former employer. I work about 90% for Oil and Gas but my next job is two soot blowers at power plant in western NE. I tried office work for about a month. Got it out of my system very quickly and never tried again. Doing it about 40 years with few short interruptions.
   / Moving to the 1st world #109
But are you electrical? You sound mechanical.
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A52377)
2006 Intellistrobe...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
