Honda ht 3813 lawn tractor deck parts
   / Honda ht 3813 lawn tractor deck parts #1
scottdanny22
soap lake washington
Honda ht3813
I have a Honda ht 3813 and I replaced the bearings in the housing that has the spindles that the mower blades attach to the problem is the threads inside both pendles are stripped very bad I need help in finding replacement spindles or is there another brand that will work thanks Scott
   / Honda ht 3813 lawn tractor deck parts #2
Can you substitute a bolt w my lock nut? Maybe drill it out for larger size first. You probably thought of and rejected that already...
Jim
Jim
i tried that but there wasnt alot of room in the shaft and Iam afraid of them coming loose and a blade flying off also not sure what grade bolt to use anew set ofthose spindles would be the ticket or if someone knows of another brand that would fit thank you for your reply
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
Safety Cones and Barrels  (A52384)
Safety Cones and...
2000 HEIL 41FT TRL PNEUMATIC TRAILER (A53426)
2000 HEIL 41FT TRL...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
