oxygen and acetalene tanks
   / oxygen and acetalene tanks #1
sam5570
south west virginia
new holland tn70
Well I just got my rent statement from the company that I rent my oxygen and acetylene and they want $470.00 for 5 years and that's to much. Where is the best place to buy my tanks from? I have seen some from $150.00 up to $800.00 and will I have a problem getting them filled. I had read something a long time back about companies not filling some tanks refresh my memory please.:confused:
   / oxygen and acetalene tanks #2
My welding supply told me if you rent for 2-years. You might as well buy the tanks. When I go in to get new tanks, the guys don't even come over to help. Just have to make sure the full tanks have a "P" on them. I just go inside and tell the counter guy what I loaded up. Been doing it this way for about 20-years.
   / oxygen and acetalene tanks #3
Same here for my welding tanks they just swap out for a new tank and no issues. For the amount I use torches I borrow my buddies the less than one time a year I need them. I have ben thinking of buying a small set from HF though.
   / oxygen and acetalene tanks #4
For almost 20 years I've used oxy and propane. I used 2 large oxy in that time and they now are empty. Lets just say I own them and don't rent but still need them , mostly for heating. I also have a plasma cutter. One more tank should be all I need. Both oxy suppliers have offered to 'slip ' one into the system for me on another account and I would be happy to pay whatever they ask but the companies are very strict as to what bottles they will accept and right now I don't have one that they will take.
Al
   / oxygen and acetalene tanks #5
I wish I had access to those lease rates. The best I can do locally for my limited usage and "medium" sized tanks is $200 a year (including taxes) I THINK that's the same price for bigger bottles which I don't need.
The only bottles I can "buy" are small ones. Rates and policies seem to vary region to region and company to company.
Terry
   / oxygen and acetalene tanks #6
My bottles have this ring on top marking them as customer owned.
   / oxygen and acetalene tanks #7
Hardly anybody rents/leases tanks anymore except large users that turn them around fast like steel shops and structural steel contractors. That way they do not have to store them after needed or worry about damage or retesting. Acetylene is fast going out of style due to cost and being replaced by propane and natural gas. Propane in the field NG in shops, Acetylene is only required if you are welding steel w/a torch or need more heat value for some odd reason. I keep an acetylene tank for the rare times I torch weld steel. I remember the days when the primary source of Acetylene was generators using carbide and water, long gone except in museums. My dad and I used one for years. The welding school I went to as a teenager had a huge generator. That was the first thing we learned was servicing the generator. It took 100# of carbide per filling (about a weeks worth of gas).
Ron
   / oxygen and acetalene tanks #8
No issues here with customer owned in Colorado. Bought my Argon tank from a local shop in Colorado Springs. They swapped it once to fill it. Had it filled by a new place here in Denver. The latest fill got hit with $10 to re-certify the tank for it's 7 year inspection. I upgraded to the bigger tank for an extra $150 or something too.
Think AirGas & some of the other big chains have issues with other people's bottles, but not most local welding shops.
Nobody has ever even asked about ownership on mine. Don't remember if they are painted or stamped customer owned.
Generally they swap out the bottles out rather than fill them. Especially ascetelene as it's finicky & special. So you own a bottle, just not a specific bottle.
   / oxygen and acetalene tanks #9
Ron
I wish that was true. I'm forced to rent bottles. $800 for a ten year lease plug gas for a typical acetylene-oxy bottle set-up. I own my argon and argon/CO2 bottles but my welding supply complains about them.
   / oxygen and acetalene tanks #10
That is the way it works around my neck of the woods also, without any problems, just swapping tanks once one is purchased for the first time.
As far as acetylene goes, even the welding or retail outlets don't refill their own acetylene tanks or any other gas and oxygen tanks. Full tanks are refilled strictly by one or two major distributors accept for propane which many smaller retailers refill on-site.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
19015 (A55788)
19015 (A55788)
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2008 GMC C5 (A53422)
2013 JOHN DEERE 27D EXCAVATOR (A52707)
2013 JOHN DEERE...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
