Changing ALL of the transmission/hydraulic oil ...
   / Changing ALL of the transmission/hydraulic oil ... #1
CincyFlyer
West Chester
Mahindra 2540
I have a new Mahindra 2540, which is coming up on the fifty hour mark, thus due for some fluid changes. I didn't think of this on my previous tractor, but I have now, so I'll ask everyone:
I have a loader, a backhoe, and a couple of skid steer attachments with hydraulics, and they all have cylinders full of "dirty" oil! The attachments won't be an issue, it will be a bit more of a chore to drain the FEL and backhoe (and get the cylinders clear of air).
So the question is: When you change the transmission/hydraulic oil, do you drain all of your hydraulic cylinders as well?
   / Changing ALL of the transmission/hydraulic oil ... #2
I don't drain the hydraulic cylinders, and I don't know anyone who does. But I've sure thought of doing so - particularly at the 50 hour mark when one would expect to see the most flushing of initial assembly dirt and metal particles.
My conclusion was that the tractor's oil cleaning system depended heavily on the filters. I think that is correct, and is probably why most tractors have several transmission/hydraulic filters. So if I didn't like what I saw in the oil I'd add in an extra filter-only change between now and the next oil change. In fact, that's exactly what I did; changed the filters an extra time.
rScotty
   / Changing ALL of the transmission/hydraulic oil ... #3
Have all cylinders stroked in; rod in as far as possible, allowing most of the oil to accumulate back in the tractor. Should only leave you with a small fraction of the total oil capacity out there in the lines/cylinders, and I wouldn't worry about that little bit. That fluid out there has also been through the filter, making it cleaner than the trash you'll see drain out of the sump at 50 hours.
Welcome to the Forum!
   / Changing ALL of the transmission/hydraulic oil ... #4
Agreed. I did the same at my 50 hr mark last week. Oil was clean but strainer did have some metal shavings but nothing critical from my point of view.
I've gotten all of the filters ($150!! but I likely didn't need them all: engine oil, hydraulic, and two for the fuel, the manual says to only replace the fuel and engine oil filters.) I'll see about whether I drain "both sides" of the cylinders; I certainly have enough oil (15 gallons of TSC premium) plus the Shell for the engine, and what's in the transmisson looks very clean in the level window. But first I gotta put on four or five more hours—and with the rain we've been getting in the greater Cincinnati area, I don't really want to trench up the property with my tires for a few days.
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2011 Ford F-350 Knapheide Stakebody Flatbed Truck (A52377)
2011 Ford F-350...
